Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 09-12-2006, 06:55 PM
aeflower9 aeflower9 is offline
Question D15B7 swap to D16Z6 Help!!!
Ok im sure people have asked this a hundred times, but one more time wouldn't hurt, I have a 93 civic DX that I just bought. The person that had it before blew up the engine and bought a D16Z6 VTEC engine to replace it. He paid a guy to put it in but the guy is a retard and did it wrong. He put the old intake on the engine which im not sure works on the VTEC engine??? So i need some help there or should i replace it with the new one. Also he did not wire up the engine correctly I know i need to run two wires from the engine, (Where are the wires from the engine are they the two that he cut off, they are at the left of the head and are at the top. If someone can assure me which wires need to be ran and if i need to change the intake manifold. i do know that i need to change the ecu p06 to p28 ecu. But not real sure where that is located. I have never worked on a honda and i have only looked at this car a couple of times, im getting ready to move it to my garage. thanks for any help
Old 09-13-2006, 10:54 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: D15B7 swap to D16Z6 Help!!!
You can use the stock intake manifold, but the d16z6 one will give you a little more power. The ECU is on the passenger side of the car, under the dash and to the right (bolted to the wall). The 2 wires are probably the vtec wires. They are infact at the top left (passenger side) of the engine. There should be 2 wires going to the ecu, as well as a ground wire.
Old 09-13-2006, 10:05 PM
Thanks for the help i should have it under control now. your info really assured me in fixing my civic. Thanks again.
Old 10-11-2006, 07:52 PM
im almost done with this swap, i can taste it!!!!! BUT ONE PROBLEM LEFT i wired everything from the engine to the shock tower and then ran the two wires from the shock tower harness through the firewall and down to the ecu. pluged in the wire to The A4 Slot in the plug at the ecu with a pin that i got from the old wiring harness and then went to plug in the wire to the D6 slot with another pin from the same wiring harness and the DAMN THING DOES NOT FIT and i can not seem to find one of those smaller pins anywhere will someone help me if you have one please mail it to me thanks!!!!!!!!!!!!!!!
Old 10-18-2006, 09:36 PM
91Z6CRX 91Z6CRX is offline
Send a message via AIM to 91Z6CRX
explain more about whats going on?
1991 CRX : Z6 Puttin' It Down.
1990 Si : B20 VTEC Puttin' ME Down.
<Down To Ground> : Puttin' It Together.
Old 10-19-2006, 04:37 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Sounds clear to me. Try filing the pin down.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 11-01-2006, 03:58 PM
it is square if i file it down then the side will fall off. i have tried to crimp it with some pliers but still would not fit. any other suggestions
http://www.honda-tech.com/zerothread...rint&id=554053
check out this link somewhere down the page you will see a diagram of what the plug looks like, look at D6 you can see that it is much smaller. thanks
