Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 09-08-2006, 08:15 PM
Acecool Acecool is offline
89 240sx will not start
Hey all, I am new here.
Anyway, I was running low on water, and oil or something, water was on the min line, filled it up again, oil was also on the minimum and I filled that up too..
Anyway, it cranks, acts like it wants to start but fizzles out...
How it happened: I had my timing change replaced a while back, when I started the car it sputtered, like it was misfiring.. Anyway the mechanic came out, wiggled the fuel injector plugs and it was fine..
So, I tried starting it yesterday, it started fine but sputtered like it was only using 2 or 3 cylinders.. I popped the hood and messed with the connections and then it shut off..
Does anyone know something I can do at home, I cannot afford to have it towed :-(
Thanks in advance,
Josh
Old 09-08-2006, 10:31 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
Re: 89 240sx will not start
check the spark plugs
check the timing
check the fuel pump
check battery and alternator too
wiggle the injectors? what kind of mechanic did u go to?
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 09-09-2006, 08:52 AM
He did my timing chain for $600, instead of the Nissan dealer for $1500...
Here are some pics:
htp://www.acecoolco.com/engine.jpg
htp://www.acecoolco.com/engine2.jpg
htp://www.acecoolco.com/engine3.jpg
htp://www.acecoolco.com/engine4.jpg
Old 09-09-2006, 01:58 PM
alow me to fix ur post if you may plz...
http://www.acecoolco.com/engine.jpg
http://www.acecoolco.com/engine2.jpg
http://www.acecoolco.com/engine3.jpg
http://www.acecoolco.com/engine4.jpg
so did u check the check list i posted?
E.K.
Old 09-09-2006, 02:43 PM
I had the timing chain done a little while back.
Spark plugs are plugged in fine.
Havent checked the fuel pump yet, listen for the humming?
Battery is strong, it still turns over strongly..
Old 09-09-2006, 03:23 PM
http://www.automotiveforums.com/vbul...d.php?t=615127
E.K.
Old 09-09-2006, 07:25 PM
The pump seems to be priming when I turn the key, and liquid does not burst out of the radiator leaving the cap open so the head gasket should be fine..
I think it is with those plugs I played with..
Does anyone know what the plugs are called that are marked on
Thanks
Old 09-11-2006, 10:08 PM
SOLVED..
I played with the MAF I think it is (Mass AirFlow sensor plug ontop of the stock air filter unit) and it fired RIGHT UP.
Have a rough idle that goes to 500 / 600, but it clears up after a few seconds...
I still need to reattach the "staples" for each of the injector clips and 2 others which I cleaned out.
I am posting this as a resolution for those of you that encounter the same problem..
ALSO... I had it running where it would stall if I went under 1k rpm, and it would rev limit and bounce off of 2500 rpm...
Keywords: rev 2500 stall bog injector fuel spark plug
Thank you to everyone for allyour help, I am sure I will stay a member and communicate with everyone about other random stuff :-)
Old 09-12-2006, 03:08 AM
happy for u bro good job!
E.K.
