Old 09-07-2006, 03:16 PM
laneet88 laneet88 is offline
Send a message via AIM to laneet88
Braking Vibration
A few months back I had new brake pads put into my 89 Civic. Shortly after I noticed when braking hard there was a very noticeable shudder and vibration. I thought perhaps it was just the new pads breaking in or something and never took it back to get it looked at even though I should have. I'm still having the same problem and I was wondering if anyone has ideas as to whats causing the vibration and shudder. Any help is apreciated. Thanks <3
89 Civic Hatchback - Pretty much stock minus the paint and Acura rims
Old 09-07-2006, 03:24 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Braking Vibration
When you replaced the pads did you replace/have your rotors turned? A warped disk will cause vibration.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 09-07-2006, 04:12 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Sounds to me like your rotors are warped. I'd just get new ones from like autozone for around 10 bucks a pop. The brake vibration can not only get to be annoying, but can also wear out your lower balljoints and some bushings.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 09-07-2006, 08:07 PM
C8H18Blood's Avatar
C8H18Blood C8H18Blood is offline
Yeah it'll definitly be beating your suspension up. I'd replace the rotors ASAP.
Cardomain.com Page
Old 09-07-2006, 10:19 PM
viper-blue's Avatar
viper-blue viper-blue is offline
I agree with those guys...air in the brake lines can cause a shudder to, but you would notice your brake pedal going down towards the floor if that were the case and by the sounds of things you didn't have any brake lines removed recently. My rotors were warped when I first bought my car and the rotors looked fine when I took a quick glance and the car passed the safety inspection no problem...I got sick of the vibration and swapped out the rotors...no more vibration
Old 09-07-2006, 11:28 PM
Hybrid1990crx's Avatar
I'm a tech at a stealership so I see alot of beat ass cars alot, and I've never gotten a virbration from ait in the lines, since the system can't even provide enough clamping force in the line due to air not being able to be compressed in the same way as a liquid.
anyway, it could be from a rust ridge, or just from the rotors being old and warped. best bet would be to just get a new set of rotors, turing them will cost about the same price.
Old 09-08-2006, 06:07 PM
sounds good a appreciate all the help.
