Old 08-28-2002, 03:40 AM
thebobs's Avatar
thebobs thebobs is offline
Unhappy well that can't be good
the tach on my car is, well, fucked. it operates normally under easy driving conditions, but when u step on the gas it goes crazy! The needle jumps all the way past redline, bounces back and basically looks like a heina on crack. I think it might be a problem with the linkage, but a mechanic couldnt find any problems. If anyone knows what might be wrong, plz help me out, and if not what is your recommendation for a supplement. (Shift light, aftermarket tach etc.) thanks for your time
Old 08-28-2002, 12:54 PM
Tominos Tominos is offline
past redline? are you sure your rev limiter works? well even still, i would get an aftermarket tach, more accurate and light comes on to tell you to shift.
Old 08-28-2002, 02:02 PM
tenzoracerevovii tenzoracerevovii is offline
yea. i think an aftermarket tach would do ok to solve that problem. and of course it comes w/ the shiftlight as tominos said so you can use that to your advantage.
i have type-r stickers on my bike, will it go faster?
-me
Don't you know, it's 10 hp for every sticker, 50 hp extra for every additional inch of rear spoiler behond stock height.
-obiewancoyote
Old 09-04-2002, 09:57 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
Have you checke for codes...?
Might take a look at the igniter, they have a tendency to cause the tach to go crazy, when they start showing signs of failure, or the coil.
Either one could be breaking down, under a heavy load. It really has to be taken to a shop, with the right kind of meters. In order to put it under all the different operating conditions for testing... If you don't want to keep re-placing parts, until you find the right one... hehehe
"Noth'in like Induction..."
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 09-04-2002, 12:17 PM
thebobs's Avatar
i]
[/b]
? codes ?
saturn rental cars do WONDERFUL e-brake slides
Old 09-04-2002, 07:40 PM
Originally posted by thebobs
? codes ?
ECU trouble codes. They are signals that the ecu emits showing wat's wrong with your car. OBD for ya. I think someone else should explain in more detail, cuz i sure don't know what i'm talking about
-me
-obiewancoyote
Old 09-05-2002, 02:11 AM
thebobs's Avatar
i dont think that will work!
a tach is electrical, its not linkage. when u put an aftermarket tach on, u have to tap into the wire that gives the signal to your stock tach. So wouldnt i have the same problems with an aftermarket tach?
Alls well that Ends well Gsizzle Eclipse 2000+ 1 10-14-2005 02:00 PM
well thats the end of that TerminalVelocity Stress Release 31 07-14-2005 01:08 PM
well thats never good... snowball1288 Wheels/Tires/Suspension 2 07-03-2005 02:45 AM
