Old 09-06-2006, 10:32 AM
2Legit84 2Legit84 is offline
1996 dodge Caravan, Blower Motor only works after hitting it
Every time I start the van up I have to give a small kick to the blower motor and then it starts working. After it starts working I can move it to different settings with no problems......Do I need to replace the entire unit?
Old 09-06-2006, 11:03 AM
jdl jdl is offline
Re: 1996 dodge Caravan, Blower Motor only works after hitting it
Are you whacking the blower motor or the control panel? If it's the blower motor, just replace that. If it's the control panel, sounds like a loose connection. You can check before you replace anything.
Old 09-07-2006, 10:44 AM
HeadlessHorseman's Avatar
HeadlessHorseman HeadlessHorseman is offline
Send a message via AIM to HeadlessHorseman
You're gonna crack the Blower Motor housing if you continue to do that. If that happens, you won't get as much air through the system. More...
http://www.automotiveforums.com/vbul...d.php?t=340871
