Old 09-04-2006, 06:11 PM
00safari 00safari is offline
difficulty taking off fan clutch
hello,
i'm trying to take off the fan clutch but can figure out which way to unscrew it...is it clock-wise or counter-clockwise?
any info much appreciated, i'm a mechanic and would gladly help out with any problems you may have just email me
thanks,
alex
Old 09-04-2006, 06:22 PM
maxwedge maxwedge is offline
A990 racer
Re: difficulty taking off fan clutch
Welcome to AF. What year is this truck? Try and post all pertinent info in the future.
Old 09-05-2006, 09:00 AM
Blue Bowtie's Avatar
Registered Offender
If this is for your 2000 Safari, the water pump hub has a M30 X 1.5 RH thread. Turn the fan nut counter-clockwise to remove it, just like you would with 99-44/100% of other fasteners you would encounter. You may need to use a strap wrnech to retain the water pump sheave and a mallet and a large wrench on the nut to break it free. With your fourth hand, you can take a picture.
Old 09-05-2006, 10:51 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Originally Posted by 00safari
hello,
thanks,
alex
Like maxwedge says we need info.
Tips on getting a good answer to your questions.
People trying to answer your question do not have a crystal ball.
So give them all of the info you have like year make and model and engine and transmission.
Also service cars engine and transmission service history or any recent repairs or problems.
Also a description of your problem and what it is doing or not doing.
If you have codes give up the code no.
And remember a code does not say replace the part but only points to the problem that you have to check out.
So to better help you give up all of the info you have on it.
MT
MT
Old 09-09-2006, 11:11 PM
old_master's Avatar
Advisor/Moderator
Advance Auto and Autozone both loan the tool kit to hold the hub. It also has the wrench that fits the water pump retainer. Like any job, if you have the right tools, the job's a snap. (Right hand threads, righty tighty lefty loosy.)
