| Maintenance problems, fixes. |
Burning Oil...
i think my car is burning oil, cause i just fixed and oil leak like a week ago. they gave my car a full oil change, using 10W40 oil. today, the check oil light came on and i checked it, and it showed i had like barely a drop of oil left. it burned so quick. i called the body shop up and they told me i might have to replace my piston rings, will this solve my problem? im going to put in 20W50 oil and see if it still burns fast. i hope not...
Re: Burning Oil...
Good luck G20er |
I'm wonderin...
I wonder if there is a problem with the oil filter not secured properly and oil coming out that way???...
-Brian Jones I got a snake man |
im just going to wait for about another 1500 miles and see if i am burning oil too fast. i hope not, cause theres more money that could be spent on mods.
can you think of any other reason, other than the piston rings, why it would burn the oil so fast?
If you're burnin' oil...I would think that your exhaust would have some white smoke to it? Is this the case? can you see or have someone else look?
the smoke if from the unburned oil i think?
well, my oil is just burning too fast.
Get someone to follow you and then tell you if its coming out your exhaust.....one of the best ways.
If there's no oil leaks that you can see i'd go and get the compression test done. Check your plugs and see what they look like...is there oil on them ?? Does your car smoke really bad at start up......may be the valve seals ? But if its using it as fast as you say it is and there are no leaks....i'd say shes burning it.
Current Build.....1/12 Scale Camaro......Almost finished!!! ![]() ![]() View All My Models Here. |
Burning Oil
:frog: I think that some of them are heading you in the right area but a leak down test is a better way of finding your problem. A compression test can still show good cylinders. But a cylinder can still be bad. Just a helping hand dude:frog: [size=3][font=courier new][color=limegreen][font=times new roman][size=4]
