Old 08-31-2006, 09:30 PM
Shadow_1967 Shadow_1967 is offline
99 Blazer Headlight flickers
On occassions my 1999 Blazer headlights flickers when I hit a bump. It doesn't happen all the time. I have had it in the shop and they can't find anything wrong. One mechanic suggested the body computer might be bad. I have pulled and bumped everything, but I can't make the lights flicker. Any suggestions?
Old 08-31-2006, 11:44 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 99 Blazer Headlight flickers
Have you unconnected the electrical connectors to that actual bulbs and clean and reinsert them?
That and check all your grounds.
Sounds like your mechanics should be avoided, the computer doesn't control the headlights so I have no clue why they mentioned that for.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-01-2006, 05:24 AM
muddog321 muddog321 is offline
AF -Advisor
Oh yes, well as LT said check those but also see if they flicker or could be the mounting bracket (composite plastic) is broken in one of the locations such as the top closer to the hood. Those 2 plastic flat slides that stick up behind the front support behind the headlights hold them in so pull straight up and then the whole assembly comes off - check for broken mounts - had one and same effect over bumps.
Old 09-01-2006, 05:30 AM
Would this cause both headlights to flicker at the same time?
Old 09-01-2006, 05:42 AM
AF -Advisor
Doubt it unless both broken and thats a stretch. How is the alternator - is it about 14v on the gage - low output could also cause. My 99 looks like the light flicker when I have the factory fog lights on (switch on headlight switch) as they always bounce alittle on big bumps and thats normal.
Old 09-01-2006, 06:16 AM
My lights actually goes out for a few seconds and then comes back on. The park lights, tail lights or any other lights do not flicker at all. I will check the alternator output.
Old 09-01-2006, 07:15 AM
BlazerLT's Avatar
AF -Advisor
Check the headlight relay and all wiring going to the headlights.
Old 09-01-2006, 09:57 AM
alblogg's Avatar
alblogg alblogg is offline
Question Re: 99 Blazer Headlight flickers
Does this happen on both hi beam and dim?
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 09-01-2006, 11:56 AM
Yes. It happens on hi beam and dim. When it happens, no other lights are guages change. They stay constant.
Old 09-01-2006, 05:06 PM
Ultrashock's Avatar
Ultrashock Ultrashock is offline
The bumps are probably causing a connection to come loose
do what blazerLT said
92 S10 Blazer Sport
4.3l Vortec V6 (W)
275,000 miles
Jasper engine, Rebuilt tranny + rearend
04 Pontiac Grand Prix GT
43,000 miles
Old 09-01-2006, 05:30 PM
Blue Bowtie's Avatar
Registered Offender
There is a remote possibility that the ballast is shorting intermittently, or the HID lamp itself has the cathode shorting periodically. You could switch the lamp from one side to the other and see of the problem moves with the lamp or remains with the fixture.
This, of course, is all in speculation that you have HID headlamps.
Old 09-03-2006, 07:59 PM
BlazerLT's Avatar
AF -Advisor
Blazer's didn't come with HID.
