Old 08-25-2002, 06:34 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Audio Questions (subs)
Hey all...
Currently working on my sub box, and I had a question about mounting the subs...
On some systems, I've seen people mount the subs upside down so that the magnet is outside of the box.
Two questions regarding this:
1.) What are the benefits of doing this (or drawbacks if that's the case)?
2.) In order to do this, do you reverse the polarity of the signal wires so that it pulls instead of pushes?
My hope is that by doing this, I will be able to increase the internal volume of the enclosure, plus it would look hella tight...
I would really appreciate some help on this!
Edit: Also, wanted to let you know that what I am building is a sealed fiberglass enclosure for two 10" Kicker Solobaric subs if that makes any difference for mounting them inverted...
Thanks,
Mike T.
Old 08-25-2002, 06:38 PM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
1 disadvantage is that the sub is open and so things can hit it and metal objects may be attracted to the magnet. yes you reverse the wires
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 08-25-2002, 06:42 PM
ci5ic's Avatar
Cool. I can deal with that.
Since the speaker cones would be concave instead of convex, does it disperse the bass in a wider range (instead of having a cone shaped propogation area)? Does it give of more bass or less?
Old 08-25-2002, 07:33 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
I don't think that using the magnet outside the box will work as well as you think. That set up is more of a "free-air" setup, and free-air setups need special free-air subs.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 08-26-2002, 03:36 AM
spy54's Avatar
marc-os that is only if he does not reverse the polarity of the woofer if he does then it sucks and doesn't blow out the air so it's creating the same affect as if it was inside the box except now he was more room in the box it shoudl produce the same or maybe more due to space in the box, more bass
AF Teen Crew
Old 08-26-2002, 04:17 AM
ci5ic's Avatar
Well, they are solobaric subs... I was under the impression (correct me if I'm wrong) that solobaric subs are the same as free-air subs?
Old 08-26-2002, 08:22 AM
zcmadman's Avatar
zcmadman zcmadman is offline
Send a message via AIM to zcmadman
u mean reverse the pos and the negative? b/c i did it w/out reversing anyhting and it sucked, so i put them back.
Don't let my car fool you, b/c my treasure is in Heaven! My car is just a slice of it.
Audio Question dr-kruwell Camaro Discussions 2 12-30-2003 08:41 PM
jl audio question azncboi2k3 Car Audio 3 09-20-2002 04:49 PM
Audio Question BlueMaxKnight Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 06-24-2002 02:35 PM
Proud New Owner with Warranty & Audio Questions Net Doctor Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 06-18-2002 04:11 PM
audio question Skeme1 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 06-14-2002 02:16 PM
