Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 08-28-2006, 10:55 PM
eS42o eS42o is offline
passlock
do i really have to install a new instrument panel cluster to fix my passlock problem? 96 buick skylark , the theft system light flashes, car will not start. if i leave key in on possition for ten min the light will stop flashing , car will start . is it the lock cylinder? what is my problem
Old 08-29-2006, 11:04 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: passlock
Welcome to AF.
On Passlock VATS systems the key lock cylinder is the transponder device that sends the right signal to the theft deterrent system so the vehicle will start. So the lock cylinder is a possibility.
Timeslip 08/12/06
AF Community Guidelines
Old 09-04-2006, 11:22 AM
Blue Bowtie's Avatar
Registered Offender
Re: passlock
This is a "Dumb Guy" question, but wouldn't a '96 have a PASSKey system, not a PassLock?
Old 09-04-2006, 12:15 PM
BNaylor's Avatar
Re: passlock
There is no dumb question. As you already know if it is a Passkey I/II it will have the resistor pellet on the key. However, I believe the '96 Buick Syklark models have Passlock I, therefore no resistor pellet.
Also, this problem may be the IP cluster since a module for Passlock is located there.
Timeslip 08/12/06
Old 09-08-2006, 10:46 PM
Re: passlock
yeah there is no resistor pellet
i may have fixed the problem!
or so it seems for the time being
i sprayed carb cleaner in my lock cylinder
my car has started since , today is day 5
about 25 times it has turned over with no waiting period
