Old 08-25-2002, 08:36 AM
gold 89 gold 89 is offline
Question check engine light
Help, formerly a v dub man i now oun a gold 89 the check engine light came on last night at 181007 or something just wondering if it was cor something or just the idiot light. turned car off and on again and light went out. thanx
Old 08-25-2002, 08:55 AM
88sedan_civic 88sedan_civic is offline
Send a message via ICQ to 88sedan_civic
that's happening to mine too, i'll find out tonight and let you know bro.
90' Toyota Supra Turbo
Mods:SP63 Turbo kit .68A/R Qtrim. HKS GT 60mm wastegate, JE pistons,Crower rods,Ferrea valves,port&polish head,AEM camgears,Webcams camshafts,HKS 1.2 MHG,MKIV TT intake manifold, Hybrid Intercooler, HKS carbon titanium exhaust system, 3'' custom downpipe, RC720cc injectors,HKS EVC IV,PHR ecu,Blitz ssbov,Chevy TH400 3spd tranny,Hurst shifter,Bosch 1000hp fuelpump,Cartech Fuel Pressure Regulator,Unorthodox Racing pulleys,HKS twin ignition system,custom driveshaft, and a K&N
Old 08-25-2002, 11:48 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
check engine light is trying to tell you something is wrong. you need to check your ECU error code to find out.F.A.Q & ECU codes
pull up your carpet on the floor board under the glove box. it sounds like something scary to do but, really it's not bad after you try it .
you'll see a shiney metal box...there is what looks like a little eye in the center...that's the L.E.D. stick your key in ignotion and click it over once (don't actaully start the car ) you'll see the led blink in a series. count the number of blinks. that number = error code. check the link above for what the error codes stand for.
ami
EDIT: i forgot to mention. you might want to count the series of blinks a couple of times. it is possible to have 2+ error codes at the same time. so, if you count 2 or more different numbers...you're not going crazy, you have 2 errors
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 08-25-2002, 11:58 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
If nothing is actually wrong, disconnect the battery from the car for like 15 minutes and that should reset the ECU so it won't throw bad codes.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Check Engine Light..... Stinff Equinox 2 11-01-2010 11:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 11:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 03:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 06:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 07:40 AM
