Go Back   Automotive Forums Car Chat > Buick > Skylark
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-26-2006, 12:53 PM
fayiz hilal fayiz hilal is offline
1992 buick skylark does not restart after running
The car starts well when it is cold . After 15 min driving it would stall at a stop sign. It does not start immediately until cooled down or a spray of startig fluid in the air intake.
Also after driving for 20 min at 65+mph , the car suddenly died , and no starting fluid would help it start .
It started after it got cooled down.
Any suggestion.
FH
Old 08-26-2006, 07:38 PM
Blue Bowtie's Avatar
Registered Offender
Re: 1992 buick skylark does not restart after running
Is this a 3.1L V-6?
Old 08-27-2006, 12:31 PM
it is quad 4
Old 08-27-2006, 12:33 PM
the engine is a quad 4
Old 08-27-2006, 11:24 PM
Registered Offender
Instead of administering starting fluid at the air intake, make sure the fuel pump is running. If I'm correct, the Quad 4 used a modified PFI system with four injectors. Fuel pressure of at least 28 PSI is required for the injectors to operate. The fuel pump should run a two-second prime cycle when the ignition is first turned on. If the relay which switches power to the pump fails, the pump will operate via the oil pressure switch as soon as the engine is cranked long enough to build oil pressure above 7 PSI. Administering fuel manually and the resulting startup would be enough to force the pump to run and keep the engine running.
The injector timing is derived from the crank positon sensor, but the ignition timing also uses this sensor, so by administering fuel and getting a successful start, you are all but ruling out the sensor as a problem. Are there any error codes (does the "CHECK ENGINE" lamp remain on after the engine has started)?
Old 08-28-2006, 06:28 AM
Thank you for your reply
Yes i am getting 28lbs of pressure from the fuel pump.
I cannot explain how every thing died when i was doing 65mph
thanks
Old 03-02-2007, 09:46 PM
bjanish bjanish is offline
did you ever correct the problem. i have checked everything also. need help.
Any suggestion.
FH
Old 03-03-2007, 11:05 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Sorry but this is old thread. I recommend starting a new thread concerning your issue. Thread closed.
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
