Old 08-23-2002, 12:41 AM
BullShifter's Avatar
Lightbulb Front Bumper Removal
1. Remove bumper lights : 2(per side) phillips screws
2. Remove the bulbs from the sockets
3. Raise & support car properly(not required)
4. Remove 2(per side) 10mm bolts under the car
5. Remove 2(per side) phillips screws inside each fender lip
6. Remove 2(per side) 12mm behind each bumper light
7. Pop the corner off were you removed the screw on the fender lip
8. Take care when removing
The bolts behind the bumper lights usually have a good amount of rust, spray some WD-40 or similar product to aid removal
Re-install
I install the bolts behind the bumper light first(leave them a tad loose)
then install the rest of the mounting hardware. And the adjust fit & tighten the bolts(do not over-tighten)
This is for 91 Civic Si(hatchback)
other models may differ slightly or if your car has been hacked up by a body shop
Old 08-23-2002, 11:28 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i get that question a lot. i'm currently collecting info for a new how-to's section. mind if i copy that and add it to the site? it will be one less thing to type up
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 08-24-2002, 01:48 AM
:smoker2:
Sure go right ahead
Front bumper removal Z Nation Nissan 350Z/370Z | Infiniti G35/G37 Coupe 1 12-14-2003 06:16 PM
Front Bumper Removal 2k1 neon es Neon | Plymouth Neon 1 10-06-2003 08:12 AM
Help! Front Bumper Removal rottenrog Accord/TSX/Accord Hybrid 4 08-09-2003 10:08 AM
Getting Dirty: Front bumper removal Halcyon 3000GT/Stealth 0 01-25-2002 04:26 PM
