Old 06-10-2003, 07:29 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
help with D16Z6 swap....
Help on a swap please!
I've read all the swap tuturials on honda hybrid and visited the d-series forums. I also read mechanic-b's swap info and still am a little confused. EVERY place says something a little different.
I have a 89 civic lx. I just picked up a d16z6 W/everything...complete swap...I have everything from the car......block,head,distributor,vtec solenoid, ecu, and engine harness. I don't know what I should do. Should I use an 88-91 Si ecu and distributor on the Z6 and modify the engine harness or should I just do the whole OBD 1 swap. Would I encounter any problems? keep in mind that I have everything. How would I do the swap if I wanted to use the D16Z6 ecu, harness, distributor, and engine? Since I have the harness and ecu, I don't have to do and extra wiring and splicing right?
thx
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 06-10-2003, 12:34 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
I suppose that it's possible for you to use your LX ecu and dizzy, but you'd still have to buy a VTEC controller or an RPM activated switch... Personally, I would run the P28 Ecu and dizzy (from the z6), and get a wiring harness adapter from [email protected]
They're $170, but worth it since you just plug it into the P28 ECU, and then plug your LX harness into it, and then you just have to run 8 wires into the engine bay from the ECU for OBD1. Otherwise, you're going to be hacking and splicing for a while and it'll probably get you all confused...
Old 06-10-2003, 12:36 PM
91civicDXdude's Avatar
you cannot use the PM5 ECU with an MPFI injection set up, so unless you want to keep your DX DPI injection, which ofcourse you dont, then you're going to have to swap to OBD1, or find an OBD0 MPFI set up.
Old 06-10-2003, 12:45 PM
bambam89lx's Avatar
AF - Advisor
I don't want to use the LX ecu and dizzy. I have the D16Z6 dizzy and ecu AND engine wiring harness. I was wondering if I coud just do the complete swap over and not have to do anything. like use the D16Z6 ecu and harness. Would I still have to get another harness and if so why?
Old 06-10-2003, 12:53 PM
ci5ic's Avatar
My bad... I was thinking that LX's were MPFI...
Old 06-10-2003, 01:01 PM
bambam89lx's Avatar
AF - Advisor
Does anyone know about the 4 wire O2 sensor? I've been hearing that my car won't work unless I add that to the cat. But, I already have a gutted cat. Will the O2 sensor bug out if I add it? Also, If I decided not to add it, will it still start and will it trough an ECU code? I know I would need it for emissions testing but I dont' feel like using it right now.
Old 06-10-2003, 01:12 PM
jusg19 jusg19 is offline
yeah i agree, if he has the whole harness from ecu to engine, why does have have to add wires? it'll already have the plugs for MPFI and all the vtec stuff
Old 06-10-2003, 01:14 PM
if you use the d16z6 engine harness, i belive that the main plugs may be differnt (where the engine harness plugs into the dash harness). Even if they are the same, you'll still have to run wires from that harness into the engine bay to the ECU, as well as convert the ECU plug harness to OBD1, which means a complete rewire.
Old 06-10-2003, 01:20 PM
let me see if i got this, all the wire harness in the engine goes to a plug near the fire wall, then on the inside there is another plug that you plug into and go to the ecu? I thought the harness was all one long piece, like from the ecu to the MPFI for example. if i'm wrong, thanks for clearing this up, becuase i want to do the same swap
Old 06-10-2003, 01:44 PM
toronto pimp toronto pimp is offline
Dude, get that yellow shit off your car.
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 07:48 PM
help with head swap d16z6 on d15b2 hondahead420 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 12-31-2003 10:36 AM
help with b16 swap need parts and help 92b16si Engineering/ Technical 1 12-08-2003 01:19 AM
Need help with tranny swap!! Miles B '71-'87 Civic | CRX 9 12-31-2001 12:07 PM
Need help with engine swap !!!!! streetmaster1 Integra 2 09-24-2001 06:23 PM
