Old 08-19-2006, 08:51 AM
nightwalks nightwalks is offline
Brakes locking up when cold....
My 1998 Astro AWD's brakes (not sure which axle) lock up first thing in the day when rolling from stop. Only happens a few times, or until I drive a mile or so. No matter how lightly the pedal is pressed, the vehicle stops hard and grabs.
Here's whats been replaced already: Rotors, Calipers, Pads, Both front hoses, slides are lubed and everthing is bled. Rear drums, shoes, all hardware and all bled there also.
I am pulling my hair out trying to figure this one out....any takers?
Old 08-19-2006, 10:08 AM
Blue Bowtie's Avatar
Registered Offender
Re: Brakes locking up when cold....
Does the van have an ABS system? Does it have an hydraulic power assist unit or vacuum?
Old 08-19-2006, 12:51 PM
All Astro Vans have power-assist, and yes, it has ABS. No codes or indicator lights in the ABS system
Old 08-19-2006, 03:32 PM
CD Smalley CD Smalley is offline
Yes they all have power assist. But which kind of assist is what BB was asking? Does it have a vacuum assist or hydro-boost assist?
Sounds like there might be some grease getting out of the rear axle onto the rear pads to me. Just something to look at.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 08-20-2006, 05:49 AM
It has vacuum power assist. No grease on any of the linings, they have all been cleaned a few times. ????
Old 08-20-2006, 10:32 AM
Registered Offender
Thanks for the reply. I asked because about 1998-99 is when they were changed from vacuum power boosters to hydraulic assist boosters. Some of the early units had trouble with the valving/reaction mechanism and would "stack up" hydraulic pressure with no pedal input, resulting in locked brakes as you described.
Old 08-20-2006, 11:17 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
You can't/shouldn't clean brake linings with anything. Next time use masking tape over the linings to keep grease n stuff off 'em.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 08-20-2006, 11:27 AM
The linings are/were new, in "cleaning" them, brake cleaner spray (only) was used to eliminate any chance of stray grease on the surfaces, I am well aware brake linings cannot be "cleaned" conventionally.
I will further investigate the possibility of an ABS or proportioning valve issue. Thanks for your help.
Old 08-20-2006, 11:42 AM
I was taught that was a no-no as well...
Old 08-20-2006, 12:30 PM
scottnhalifax scottnhalifax is offline
it could also be the adjustment plugs are missings which causes condensation to get in..
that may be your problem
2000 safari awd
