Old 08-21-2002, 09:39 PM
rodss67 rodss67 is offline
Unhappy Speaker Problem
My front speakers in my 98 Integra work intermittingly. Sometimes when you hit a bump they will come on for a short time. I checked the connections and they appeared to be good. This is the factory system. Any help?
Old 08-22-2002, 12:11 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
sounds like you have blown the speakers.
Old 08-22-2002, 04:22 PM
so-cali so-cali is offline
that doesnt sound like blown speakers to me. i dont think that blown speakers just decide to turn off and on from time to time and whenever you hit a bump.
When i put my aftermarket eclipse's in i had sorta the same problem with the sound turning on and off. I the speakers out and found that i had done a poor soldering job and bits of the wire would touch other parts of metal on the door and each other. everytime the wires would shift around in the speker housing the sound would stop and then come back on a few minutes later.
My advice would be to take all the connections off and check the wires and harnesses and everything. Look for breaks in the insulation of the wires and then make sure the harnesses all have a good solid connection with the wire and connector when you put everything back together. My guess is that it turns on when you hit a bumb because some connection is made that wasnt there before when the wire shifts position.
If you still have problems, test a different pair of speakers from a buddies ride that you know work and see if the same problem arises. If its solved with the new speakers then your factory ones dont work. If its the same then you've got a problem with something in the car (probably the cd player, head unit, wiring, fuses, etc.)
1991 Acura Integra
Pioneer DEH-3400 Head Unit
Eclipse 82641 Speakers
4-ch 1000 watt Sony Amp
2 12" MTX 5000 subs/Bandpass Box
Old 08-24-2002, 10:33 AM
Audio Guy
strangely enough, they do .... a blown speaker is usually where a part of the wire in the voice coil has been burnt thru. It has a problem playing because it is an open circuit at the neutral position. When you hit a bump, it can change that and start playing for a while. Since these are stock speakers, you don't have to take the door apart to look at the wiring - since it isn't anything you could have messed up. If this were an aftermarket system then I would start checking all the wires first.
Old 08-24-2002, 11:01 PM
if your car is still under warranty, take it in and let em fix it for you. if not i would still try another pair of speakers and see if the prblem continues
1991 Acura Integra
Old 08-28-2002, 12:12 AM
Whitey001 Whitey001 is offline
I agree either its a bad voice coil in the speaker or the harness thats connected to the speaker or at the deck going to the speaker:greenchai
Old 08-28-2002, 04:47 AM
thebobs's Avatar
thebobs thebobs is offline
your speakers might be hittin a ground. my brothers ride had the same problem. check all your wiring and make sure no bare metal is hitting an expose wire
saturn rental cars do WONDERFUL e-brake slides
Old 08-28-2002, 05:34 PM
Audio Guy
again ... I would find that easier tobelieve if it were aftermarket - most OEM systems don't seem to have the wiring problems, they are designed to be trouble-free.
Old 08-30-2002, 08:56 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
honda/acura stock radios are notorious for going bad.....im a honda tech, we dont normaly see bad wires(ever) or bad speakers(rarely) but see radios go bad....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 08-31-2002, 03:42 PM
Audio Guy
I guess that would never occured to anyone on here .... the first thing we do is ditch the factory stuff
Old 09-02-2002, 11:34 PM
gunnmen01's Avatar
lol , i wonder about that.....tossed mine awhile ago....
gunnmen01
Old 09-10-2002, 08:19 AM
sickhonda's Avatar
sickhonda sickhonda is offline
Totally agree with gunmen01 on this!!
I guess, one thing Honda never paid attention to!
I had the same problem so I did some research, found out most Honda/Acura Recall Listing have the OEM radio listed as such, DEFECTIVE. That's normally the described symptom. The recall is never implemented by manufacturer, since the problem will not lead to any harm/danger to public or individual. To all Honda/Acura owners, save yourself the trouble of checking the wires, replace the HU, like I did.
Speaker Problem? MY rear speakers and front left door speaker do not work? chrstuck Blazer 6 03-24-2006 01:03 AM
speaker problem vietxxxtasy Car Audio 6 03-17-2004 11:04 PM
Speaker Problems! rob_whiteman Car Audio 3 03-01-2004 02:27 PM
speaker problem dgibb Aurora 1 12-25-2003 02:25 AM
92 wagon speaker problem skeefree Accord/TSX/Accord Hybrid 5 05-30-2002 07:19 PM
