Old 08-20-2002, 10:37 PM
coonass420 coonass420 is offline
Send a message via AIM to coonass420
engine serial number ID
i justwanted to check and see if my b16a1 came out of a car with an auto ormanual tranny car i don't want t over ev and bend a valve. Does any one kno were i can run the number to see what it is.
Old 08-22-2002, 05:39 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
If you post the engine number it might help
I can tell the likely hood it came from an Auto car or not, as the early versions in the 90-91 CRX and Civic SiR never came with an Auto option.
While the Xsi and Rsi Integra only had the Auto as an option in 1992.
If its from a 92 on Civic/Del Sol SiR then I believe more Autos than Manuals were sold in Japan, and so it figures that there will be more floating around. However most importers should be honest enough tell you what your getting.
But the easiest way to tell is:
Loot at the ECU. If it has an "AT" printed on the Circut bourd (you will have to remove the cover) then its and Auto ECU and most likely an Auto spec engine.
And even easier way to check:
Look at the flywheel. If the engine has one, and the bolts dont look like they've been recently removed then clearly its a Manaual spec engine.
If it dosnt have a Flywheel, but a Torque Converter or backing plate then clearly its an Auto engine, or if it has a flywheel and the bolts look recently removed then it may be an Auto engine with a flywheel added.
Incase you didn't know the Auto spec engines only make about 150hp. They run milder cams and different ignition timing. As well as a differnt fuel map etc on the ECU.
Old 08-23-2002, 06:20 PM
he the serial is 5000647 thanks a bunch
H22A Engine serial Numbers TurbodLude JDM Motor & Parts info/chat 3 07-05-2005 10:22 PM
H22A engine Serial Numbers TurbodLude Prelude 0 06-13-2005 05:51 PM
Engine Serial Number ladyk325 Malibu 2 04-21-2005 10:26 PM
Engine serial number billyray63 Commercial Trucks 0 02-27-2005 03:57 PM
jdm engine serial numbers stormperformance Engineering/ Technical 0 09-11-2002 02:59 PM
