View Poll Results: When did you change your Intrigue spark plugs? (If ever?)
plugs not changed <100k miles 10 45.45%
plugs not changed 100k <-> 150k miles 4 18.18%
plugs not changed 150k <--> 200k miles 0 0%
plugs not changed 200k <---> 250k miles 0 0%
plugs not changed 250k <----> 300k miles 0 0%
plugs not changed >300k miles (you da man !!) 0 0%
plugs changed <100k miles 7 31.82%
plugs changed 100k <-> 150k miles 1 4.55%
plugs changed 150k <--> 200k miles 0 0%
plugs changed 200k <---->300k miles 0 0%
Voters: 22. You may not vote on this poll
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-12-2006, 01:51 PM
panzer dragoon panzer dragoon is offline
Poll: How long before changing spark plugs?
gap: .060"
torque: 13-17 Ft/Lbs
The Intrigue platinum plugs should last ~100,000 miles. That's about where my car is at now. I don't plan on changing my plugs this year and most likely not next year also. My Dad's 99 Intrigue 3.5L has almost double my mileage and has not changed plugs yet.
When did you change out your plugs (if ever?) on your Intrigue? (Poll)
Why and what brand did you goto? Platinum or other.
Old 08-15-2006, 09:32 PM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
Re: Poll: How long before changing spark plugs?
I just replaced mine a couple of weeks ago, a 3.5 liter with 52,000 miles on it. I know they are good for 100,000 miles, but I didn't want to take a chance on plugs seizing up in an aluminum cylinder head. So I replaced the plugs with original AC Delco, and put a little anti-seize on the threads. Ran a compression check at the same time. The lowest was 200 and the highest was 210.
Old 08-16-2006, 12:59 AM
notimprezed notimprezed is offline
My 2000 has 126k and the plugs havent been changed yet, gonna do it this week with the alternator. Hope they arent siezed. I had a 98 and never had the plugs changed, traded it with 230K on it. Not the best idea but the motor ran strong and outlasted everything else on the car. All problems with it were normal wear and tear except the new tranny at 160K.
Old 08-16-2006, 06:20 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Originally Posted by panzer dragoon
gap: .060"
Your car your choice but it would be a very good idea to change them now.
If you let them go to long they can burn a hole in piston or you may never get the plugs out.
Look at the gas you are going to save.
MT
MT
Old 08-18-2006, 04:50 PM
my dad has 150k miles + on his 99 and still gets 30+mpg. Really the prices for these platinum plugs are not that bad, I was expecting $10+ a pop but they are under $3-5 at the Rock.
My car drives awesome and it's even better after changing the coolant? = I don't want to ruin what I got. Maybe next year for new plugs.
My 1966 Dodge Charger just had it's plugs changed and I noticed a huge improvement. Plugs aren't under a $1 anymore, but they are made better and have more copper. = It's worth the change.
I remember when the split electrode splitfire spark plugs came out (1990?)
and I thought those plugs were not worth the extra $$$$.
Old 08-19-2006, 07:29 AM
2000 : OLDSMOBILE : INTRIGUE : 3.5L 214 cubic inch V6 FI (H) : Ignition :
CHAMPION Part # 13
D.O.H.C. {.050 gap} {COPPER PLUS #RS14YC6}
**Sold in packs of 4** More Info
$1.35 $0.00 $1.35
AUTOLITE Part # 605
GAP .050 {Resistor}
$1.41 $0.00 $1.41
BOSCH Part # 7571
Gap=0.050"; Original equipment is platinum or other precious metal. {SUPER #HR8DCX}
**Sold in packs of 10** More Info
$1.62 $0.00 $1.62
NGK Part # 3951
{.052 gap} {V-Power Plug #TR55}
$1.70 $0.00 $1.70
CHAMPION Part # 3013
D.O.H.C. {.050 gap} {PLATINUM POWER} More Info
$1.92 $0.00 $1.92
BOSCH Part # 4205
Gap=0.050" {PLATINUM #HR8DPX}
$2.18 $0.00 $2.18
AUTOLITE Part # AP605
GAP .050 {Platinum}
$2.23 $0.00 $2.23
NGK Part # 3403
{.052 gap} {G-Power Platinum Plug #TR55GP}
$2.42 $0.00 $2.42
AUTOLITE Part # APP605
OE Style; Gap .050 {Double Platinum}
$3.98 $0.00 $3.98
CHAMPION Part # 7013
D.O.H.C. {.050 gap} {DOUBLE PLATINUM POWER #RS14PYP6} More Info
$4.15 $0.00 $4.15
AUTOLITE Part # XP605
GAP .050 {Xtreme Performance}
$4.82 $0.00 $4.82
BOSCH Part # 4458
Do not gap. Gap is not adjustable. {PLATINUM+4}
$4.98 $0.00 $4.98
ACDELCO Part # 41980
SPARK PLUG .050 GAP {PLATINUM PLUG #12556183}
**Sold in packs of 8** More Info
$5.00 $0.00 $5.00
CHAMPION Part # 9404
D.O.H.C. {.050 gap} {CHAMPION IRIDIUM}
$6.46 $0.00 $6.46
NGK Part # 7164
{.052 gap} {Iridium IX Plug #TR55IX}
$6.58 $0.00 $6.58
DENSO Part # 5070
{0.050 gap} {Premium Plug #PT16EPRL13} More Info
$7.29 $0.00 $7.29
NGK Part # 7740
{.052 gap} {Premium Platinum Plug #PTR5C13}
$8.48 $0.00 $8.48
DENSO Part # 5325
{0.050 gap} {Iridium Power #IT16} More Info
$11.96
BOSCH Part # 4305
Do not gap. Gap is not adjustable. {PLATINUM 2}
$3.86
Notice the gap difference .050" typical <--> .060" Intrigue. And some of these plugs are not gappable (you do not gap these type plugs).
I will vouch for the cheap Champion Copper Plus at $1.35 a piece (at a .035" gap) = Worked good in my 440ci, but for the Intrigue I would definately go with Platinum since it is a performance engine and almost double the gap .060" (trust GM).
I'm just joking, What the hell do I know about spark plugs or ignition systems? (I still think ignition coils are pretty) Anybody want to try a .065" .070" .080" gap in their Intrigue?
Post about only using A/C Delco plugs:
http://www.automotiveforums.com/vbul...d.php?t=608609
Old 08-24-2006, 12:41 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Stick with AC Delco. GM designed these engines with GM factory parts in mind...they didn't spend millions of dollars in development just to have a factory part pulled and replaced with another manufacturer's part with different (although slightly) specifications.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 09-14-2006, 01:53 PM
clubplug clubplug is offline
Banned
According to NGK, you can use the following:
2000 OLDSMOBILE INTRIGUE / V6 / 3.5
SPARK PLUGS
Spark PlugPart No.Stock No.Plug GapNote
G-Power PlatinumTR55GP 3403 0.052
LaserPTR5C-13 7740 0.052
Iridium IXTR55IX 7164 0.052
WIRE SETS
NotePart No.Stock
No.6 CPB's Req'd CPB-GM001 58902
No Wire Set Req'd DFI 0
OXYGEN SENSORS
Pre/Post CatalystBankNoteNTK OE TypeOE Type WiresNTK UnivUniv Wires
Pre-Cat 21515
Post-Cat 21514
Old 09-15-2006, 01:01 PM
busboy4 busboy4 is offline
[quote=panzer dragoon]my dad has 150k miles + on his 99 and still gets 30+mpg.
Really? I have a '99 with 53K and have never seen more than about 25.5. Thats with the "shortstar" 3.5L.
Old 09-15-2006, 10:34 PM
yeah, he got the 3.5L, but keeps it 55mph (or less) to get that 30+mpg. I think he got 33 or 34 mpg on a trip once. Around town you are not going to get anything near 30mpg. Air out those tires to 36psi (or more) also.
Many smaller cars barely get 30mpg.
I am convinced my Intrigue could also get 30+ mpg, but that kind of takes the fun out of paying $3 a gallon for gas.
Old 09-17-2006, 05:29 PM
crashnburn crashnburn is offline
I put the bosch plat. in. We drove down to Florida this year. We were driving 75-80ish & we got 31 mpg. Except for in Mn. We have the 10% ethenal so the mileage dropped there. 166,000 on the her.
Old 03-16-2007, 05:28 PM
Jimmy Olsen Jimmy Olsen is offline
Wink Re: Poll: How long before changing spark plugs?
[quote=busboy4]
You would get better mileage if you would drive in "D" instead of "3".
Old 03-16-2007, 05:37 PM
Just drove out to San Diego from Oklahoma doing about 75 to 80 mph. One stretch in AZ was up to 90-93 mph. Anyway, i average about 29 to 30 mpg. It really depends if you have to drive into the wind, that will drop the gas mileage.
The car now has about 95k miles and will change the plugs at the Gm dealership at 100k.
BTw, I changed the oil just before taking the trip and the oil change place put in about 7.5 qts. (i told them the car takes 6 qts). Anyway, the funny thing is that the car didn't burn any oil on the trip where it usually would need 1.5 to 2 quarts for a 3500 mile high-speed road trip. Very unusual.
Old 08-20-2007, 10:05 PM
n0rt0n n0rt0n is offline
What I also find unusual is the guys with Intrigues in here that are getting this 30+mpg!!
My 2001 with 170,000 only gets 25mpg at an average speed of 50mph
So to the guys that get high mileage, have you regularly maintained your transmissions with new filters and fluid??? Also maybe your vehicles don't have a spoiler? (mine does, when I had it off for a day, I swear the car coasted WAY further...)
And PS, maybe the oil that the oil change place put in is a WAY different brand of oil. My intrigue will use a quart every 2500 miles with mobil ONE synthetic. BUT I changed brands and now it doesn't use ANY.
Old 08-20-2007, 10:17 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Please check the dates of the posts before posting and avoid posting in those threads that have been inactive for 90 days or more.
Thread closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
