Old 08-20-2002, 08:31 AM
obsidian66 obsidian66 is offline
Dynamat
Does anybody know what you can use instead of dynamt, its so expensive. Would rubberized undercoating do the trick. I was something that sprays on so its not as bulky as the sheets.
Old 08-20-2002, 11:25 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
nope sorry man dynamatt is thick so it absorbes the the excess vibration but also keeps the sound within the car. i guess the best way to describe is...like when you sound proof a room by hanging foam on the walls.
i know this sounds crazy but if you could get your hands on a little piece...stick it on a piece of metal. drop a little fishing weight on it...then drop on a piece of just metal. you will instantly hear the difference.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 08-20-2002, 12:08 PM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
dynomat is worth every penny in my opinion, that shit is great
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
Old 08-20-2002, 01:45 PM
So just get the sheets and cut them to fit? Is there a Dynamat spray for getting behind the rear panels on the metal.
Old 08-20-2002, 08:55 PM
DRCustom DRCustom is offline
Send a message via AIM to DRCustom
Get RAAMmat 60, it's waaaaaaaaaaaay cheaper, and at least as good, if not better than dynomat extreme. awesome customer service as well.
http://www.raamaudio.com/products.htm
Peel and seal, or an equivalent asfault based roofing product also works (very inexpensive alternative)
Old 08-21-2002, 11:49 AM
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
http://www.partsexpress.com//pe/show..._ID=7083&DID=7
Try that link. This is Dynamat w/o the logo. I used it in my bug after I used dynamat and found this. This is the EXACT same stuff! It is hella cheap too!
Old 08-21-2002, 01:01 PM
Oops, you wanted spray on
Spray on is not nearly as good as any sheet product, but Mcmaster Carr has some decent stuff (for spray deadeners).
Old 08-21-2002, 01:14 PM
jc836 jc836 is offline
Lower cost and just the same is Cascade. Check www.cascadeaudio.com. The correct install is to use strips of the stuff as needed. That is unless you have a monster proble then you can also use the liquid type.
Old 08-21-2002, 03:46 PM
I think the sheets should work good. Thats really cheap for it. How much you think I would need to do the entire car inside. I think if I order 4 sheets of 32"x54" I should have a good start. Thanks for the sites.
Old 08-21-2002, 06:46 PM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
you realize how you are all destroying technological growth right? by buyign the cheaper products not made by the original creators your making life tougher on the creator who is only being copied and now dynamat is going to just say fucduck it b/c no one apreciates what we did for sound deadening just my tantrum
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 08-21-2002, 08:33 PM
EFsleeper's Avatar
EFsleeper EFsleeper is offline
Send a message via AIM to EFsleeper
You also get the same results if you stick a piece of chewing gum on it.
I am an installer and I will tell you this, whoever invented dynamat is sitting rich somewhere. Most of the time the shit makes no noticeable difference. If you really want to know what dynamat is, I shall enlighten you. You know the black tar stuff that is "caulked" around the inside of your door panel? thats it baby. Its the stuff they put in between the plastic wrap in the door. You can buy a product from 3M called Strip Caulk. one day at work I was bored so I got the strip caulk out and rolled it together like bread dough and covered it with foil on one side, instant dynamat. Save your money.
Stop looking at my Autometer!
Old 08-21-2002, 09:42 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Just because it's the original doesn't mean its the best. All it means is that they can charge more for it because it's got a logo stamped on it. For instance, there's a ton of shoes out there that are just as good as Nike's, but they don't cost $100... Why do you think Nike charges so much for their product when it's made over-seas in sweat-shops by little kids who make like 2 cents an hour? Because they have their logo on it, and they have to re-coup some of their advertising/marketing expenses... But it's the same shitty craftsmanship that you see in tons of other products. Incidentally, did you know that the guy who designed the Nike Swoosh™ was paid only $25 for his work?
And, just so you know, technological growth doesn't come from buying the same products from the same big corporations. It comes from the consumption of NEW products from NEW companies with NEW ideas.
just my tantrum also.
Old 08-21-2002, 10:23 PM
yeah, so there!!!!
Old 08-22-2002, 10:08 AM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
edesignaudio.com
or rubberized under coat. I have used thick coats of it with sucess on odd shaped places. Just don't use it where it can get stuck to something (only under hard plastic panels, not carpet, not spare tire well) because it got hot in my car and stuff started melting together.
-Dustin
Old 08-23-2002, 11:04 AM
OldSchoolHatch's Avatar
OldSchoolHatch OldSchoolHatch is offline
Send a message via AIM to OldSchoolHatch
Would it make a difference if you just put a 1' square piece around the 6.5" round speakers in each door? I've seen just that done before and it's all I'd want to bother with, so just wondering it it's worth doing. By the way, the quality of sound is already really good in my car.
Does Dynamat quiet loud exhausts? Racerboy Car Audio 6 04-02-2002 06:10 AM
Dynamat buh_buh Car Audio 6 02-25-2002 04:45 AM
Alrite everyone who will buy some dynamat from sparq reply here CiViC-EX98 Car Audio 34 02-24-2002 05:26 PM
Dynamat Dynamat Dynamat Dynamat Dynamat nittanys1 Car Audio 12 02-13-2002 01:46 PM
Any One know a site where i can find a Dynamat trunk kit for less the 80 bux ?? CiViC-EX98 Car Audio 24 01-06-2002 10:16 AM
