Old 08-19-2002, 11:46 PM
devildrool devildrool is offline
which step 1st..
Do we Stick the bumper, spolier, side mirror to the body and spray it on 1 piece Or spray the body and the other part seperate then after the paint is dry then stick it onto the body.
How many layer of paint do you all spray it over the body and how long is the difference you all take to spray the 2nd, 3rd and so on.
Must it a must to spray a white coat over the body.
Old 08-20-2002, 12:01 AM
Ranger_X's Avatar
Ranger_X Ranger_X is offline
I keep everything in seperate peices, that way, it's easier to spray underneath the spoiler and in the crack between the bumper and body frame, plus you can sand here where you wouldn't be able to if the bumper/spoiler is already attached. Excetptions are when you want to mold a bumper or rear lip spoiler directly into the body.
how many layers depends on what type of paint I'm using or how lazy I am. Primer is always 3 coats or more depending on how much i need it, waiting at least 40 min between each. Acrylic goes on thin cause I need to thin it out for my airbrush to spray effectively, so I'll usually put 3 or more coats on, it dreis pretty quick. Enamel is thick, so 1 or 2 coats a few hours between each.. maybe even 3 if i need some hardcore polishing after. Automotive laquer is 1-2, like enamel, and clear coat is always 1 coat, hours or next day between coats
Do you mean CLEAR coat? For automotive paint that has dull or metallic finishes, it looks a hell of a lot better with clear coat. With acrylic and enamel, i think the laquer actually melts it or something, so don't use them together.
-Will-
96 M56 Volvo 855 Turbo
87 A555 Chrysler Daytona Shelby Z
Old 08-20-2002, 02:20 AM
Purpura Delujo Purpura Delujo is offline
I keep all parts seperate when spraying, like Ranger X does. You may want to put as many coats on your model as you need, just so it covers the plastic and the plastic is not visable through the paint. Read the instructions on the spray can to know how to properly aply the coats and how long to leave between coats. You should leave coats between the time it takes for one coat to go touch dry.
Old 08-20-2002, 08:07 AM
Vric's Avatar
Vric Vric is offline
I glue all body part before painting (if you can, sometime you can't cos the frame wnt fit)
Old 08-20-2002, 08:46 AM
crab's Avatar
crab crab is offline
I keep all pieces separate for several reasons. It makes spraying the body much easier... when u have stuff protruding from the body, it's easy for paint to start building up where it's closest to the can... even with light coats this happens. It also makes it easier to get an even coat of paint on the body. U may find that it's difficult to spray crevaces and areas under protruding parts... paint will inevitably start to build up around that area
In general, leave all mirrors and wings and clear parts off until the end. If the body requires u to attach LARGE body panels, say a flat bumper or a side skirt, u might want to attach those first, then use primer to seal in the joint, then spray with color.
Well, there my .02 hope it helps
Referring to pictures of *his* 996 Carrera 4...
"Why would I want to post it in the 996 section if its a 911 that I have[own]??? :huh: :huh: :huh:..."
- sizzilinS7
Boy: I pry apart that battleship you call your ass.
Boy: I see shit nuggets hanging from the hair around your asshole.
Girl: WTF?!?!?
Boy: They stink really bad.
Girl: OMG STOP!!!
Boy: I start to get fed up with your ugly ass
Which part 1st? SLPbirdy00 Camaro Discussions 13 07-14-2006 07:22 AM
Which GA GT is the fastest? 1st,2nd,3rd? spoolinmonkey Grand AM 1 06-19-2006 06:54 AM
1st step in 1st gen Spyder!! 92VR4Red 3000GT/Stealth 5 04-05-2005 10:28 PM
1st gen b16 with both o2 sensors, which header dagoEF '88 - '91 Civic | CRX | Wagon | Shuttlee 7 08-13-2004 08:01 AM
step by step for zc swap? 95civicman '88 - '91 Civic | CRX | Wagon | Shuttlee 1 03-22-2003 09:19 AM
