Go Back   Automotive Forums Car Chat > Honda > General Discussion
Old 08-11-2006, 10:35 AM
MickeyP MickeyP is offline
Handbrake light on?
I have an Integra '99.
This morning, my handbrake light was on although the handbrake was down. Also, It felt ok, it didn't file like the handbrake was on.
What do you think the cause is?
Old 08-11-2006, 03:16 PM
somick's Avatar
somick somick is offline
Re: Handbrake light on?
Welcome to the forum!
"Brake" warning light tells you about the brake SYSTEM malfunction. Check your brake fluid. I can bet it is low.
Make sure you do it right away. It is dangerous to drive like this. Next step your brake system if not replenished will suck in air and you will loose your brakes completely.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 08-11-2006, 04:38 PM
Hey, thanks for the reply.
I just checked the break fluid. It's full.
Any other suggestions?
Old 08-12-2006, 11:38 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
It's probably just your E-brake switch. If there was a brake system problem, the ABS light would be on. The E-brake light it just a simple circuit with a switch located right next to the brake lever. Take out your center consol and you'll see the switch, it's probably just jammed.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 10-09-2006, 09:56 PM
J-Wat J-Wat is offline
AF -Advisor
was it chilly outside? if you answered yes it is the float on the cap that sticks, just take it off and wipe of any gunk and it should go away
