Old 08-19-2002, 09:21 PM
noreaga0221 noreaga0221 is offline
Send a message via AIM to noreaga0221 Send a message via Yahoo to noreaga0221
gauges
does anybody know how to install an air/fuel ratio gauge? i also bought a boost gauge but i read on www.vfaq.com on how to install that but i couldnt find anything about a a/f gauge, just how to make your own. does anybody know of a site or another post discussing this issue?
loooking for my first kill....
Old 08-20-2002, 07:25 AM
aves911's Avatar
aves911 aves911 is offline
Massive Genius
Send a message via AIM to aves911
The A/F Gauge has 3 wires coming out of the back of it one goes to +12V, one ground, and one is spliced into the 02 sensor wire on the ECU harness.
Check the instructions that came with the gauge for which wire is which (mine were: red(+12V) black(Ground) and white(02 sensor)) At RRE, www.roadraceengineering.com, they have a page on installing the jumptronix digital A/F gauge. Look at the wiring diagram for the ECU harness, it shows you which wire on the harness is for 02 voltage. Installation is just putting it in a gauge cup somewhere and running those three wires.
Peace
"this is a funnie thread..
we have a poser who keeps posting information that doesn't fit together..
and aves911 keeps correcting him"
Old 08-20-2002, 11:12 PM
thanks man for replying so quick, i should be installing the pod and the boost guage this weekend so i'll let yous know how i do and i'll try and get some pictures of it.
Old 08-21-2002, 08:04 AM
aves911's Avatar
Massive Genius
No problem man, glad to help.
Post up some pictures if you get a chance.
Peace
Old 08-25-2002, 11:24 PM
well i got the a/f hooked up well kinda. i pulled a fuse out of the fuse box and wrapped the red wire around it and stuck it back in. i heard that can be your positive line. well the gauge is not back lit right now but i do see the lights jumping back and forth between lean and rich which i heard they do while you are driving. does anybody have any other suggestions for the spot to get power from?
and as for the boost gauge, they didnt even supply me with a T connector nor are the directions good enough for me to figure how to run the vacuum line. i have to take it back to the shop and ask the guys for help.
Old 08-28-2002, 05:02 PM
well its all done and mounted and looks pretty good. the carbon fiber faces really go well with the darker interior. i ended up getting a T fitting that was too big but fit into the hoses under the hood and then got another piece of soft rubber tube and slipped that over the line from the guage into the T and tightened the hell out of it with a clamp. its working damn good. if anybody needs any help feel free to contact me with questions.
hopefully i'll get pictures soon. i have a webcam but dont feel like dragging my whole computer outside for a couple shots.
Installation Connection Problem: 0-Gauge to 8-Gauge, or Alternate? OnThePike Car Audio 10 12-03-2010 12:49 PM
'04 Tahoe Range/Fuel gauge problem. usn_622 Tahoe 2 02-21-2009 09:58 PM
Should I get another gauge or just order a boost gauge? urmystlkal Off-Topic 4 01-27-2004 06:54 PM
2001 Expolrer-Check Gauge Light/Temp Gauge cmroth12 Explorer | Explorer Sport Trac 0 12-29-2003 01:11 PM
