Old 08-10-2006, 01:32 AM
sdsniper's Avatar
sdsniper sdsniper is offline
Unhappy 91 Firebird almost done fixing needs some more help
I was wondering if you guys can help. Im pretty sure the are some very qualify people that can help me out here. Me being that i dont know much about this type of problem.
So my car doesnt start. I turn the key, the starter whins and the engine turns but the engine doesnt start. I tried pulling out the altenator. Autozone tested it and its a good altenator. I pulled out my starter, Autozone tested it and found out that it was a good starter. So i put the start back on, exactly the same way it was on there and i go to connect the battery cables to the battery and the engine started turning and it was trying to start without anyone turning the key. I know this might happen if put the wires in the worng place on the starter but i didnt put them in the wrong place. Soo now im wondering why my car wont start and why when i try to connect the battery, the engine turns and trys to start and it wont stop until i pull the cable away from the battery.
Old 08-10-2006, 01:41 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: 91 Firebird almost done fixing needs some more help
Well this thread may be able to help you out. Sounds like a similiar problem another member here just recently had.
http://www.automotiveforums.com/vbul...d.php?t=602405
If that's not the case, just let us know. Might also try checking the fuel pump relay.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 08-10-2006, 10:07 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
The starter will only engage whe power is supplied to the s terminal, smaller purple wire on the solenoid. So for some reason you seem to have power on that wire. OR, thae starter was dropped and internally damaged the solenoid and it is bridged
As for the no start one of 3 things is missing:
Fuel, spark, or compression.
Old 08-11-2006, 02:27 AM
sdsniper's Avatar
Where can i find this fuel pump fuse. I know the other thread says that its next to the blower but doesnt that mean the A/C? and where exactly is it hidden? hmm
Old 08-11-2006, 02:32 AM
sdsniper's Avatar
Well i didnt drop it. But maybe i wired it wrong? theres no way because the smaller wire goes on the smaller terminal....Would taking off the starter cause the ignition switch to get stuck?
Old 08-11-2006, 09:07 AM
wrightz28's Avatar
No the swithc is on the column in the car. Are you 100% positive that the wire is not on the M terminal, which is not useed, and that the positive battery cable is in NO WAY touching the S terminal?
Old 08-11-2006, 05:34 PM
sdsniper's Avatar
Im going to double check. There are three terminals on the starter right? maybe thats whats wrong. Thank you Ill let you know what happens :-)
Old 08-11-2006, 10:18 PM
sdsniper's Avatar
I have good news and bad news. The good news is that i checked the cables on the starter and they were touching, so i fixed that and now i can connect my battery without the car trying to start on its own. Thank you :-)
The Bad News is that the car still doesnt car. All it does is turn and turn. Soo Im wondering what is wrong. I need Fuel, Spark, and Compression. I believe that the fuel pump is working because i had someone put there ear next to the gas tank to listen for the fuel. They heard the fuel pump buzz. anyway i think it might be that hidden fuse? Where can i find that?
Old 08-11-2006, 11:38 PM
Morley Morley is offline
Check the inj 1 & 2 fuses (if it is fuel injected), they are in the fuse block.
Check for spark next. Remove 1 spark plug wire and put a spare spark plug on the wire. Have someone crank the car while you hold the plug against a good ground (engine is a good one) and watch the spark at the plug. It should be bright and strong. If you have no spark, it is most likely the ignition module (only replace with an AC Delco one). If you have good spark, the next thing to do is get a noid light (auto parts store) and hook it in place of one of the injectors. Watch the light as you crank the car over, it should flash on and off. If it does...check each connector on the harness to make sure the harness is in tact. If they all check good, ohm out the injectoirs. They should read around 16 ohms, any that are 4 or more ohms above or below that should be considered bad.
Old 08-16-2006, 11:47 PM
sdsniper's Avatar
Angry Re: 91 Firebird almost done fixing needs some more help
1.[x]Fuel pump
2.[x]Fuel filter
3.[x]Starter
4.[x]Altenator
5.[x]Fuses (injector fuses and all)
6.[x]Fuel injectors (Look good)
I havent check the (7.) spark plugs yet but i think i might know what the problem is..Correct me if im wrong please....Today i was checking out the wiring connecting to the fuel injectors...It looks like a rodent(i hate em) chewed them a bit. They dont seem completly chewed but enough for the wire to show and some of the wire ripped.. I have no clue where the heck this wire runs to but it doesnt look to good :-(
i miss my birdy
ps. Thank you to all you that has been helping me fix my car. I appreciate it :-)
Old 08-17-2006, 03:26 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
there you have it, you have no fuel into the cylinder.. >_<
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 08-18-2006, 07:34 PM
sdsniper's Avatar
Well im trying to figure out if these wires go to some censors and if they could easily be fixed...here are some photos
Kinda dirty :-(
Did i metion that i hate rats. anway if there just censor wires (which will still be fixed) would that still be the problem.(wont start)
Old 08-18-2006, 11:32 PM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
timing??? if you had the distributer out and did any rotating to anything its probably off enless you lined up the oil pump drive and got the rotor facing in the cylinder 1ish direction with the #1 plug wire right where the rotor was pointing while the motor is at top dead center.
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 08-20-2006, 03:40 AM
sdsniper's Avatar
i havent touched the distributer or sparks yet.
I put some gasoline in the cylinders and the engine ran for about 3 seconds. so i know its a fuel problem now. Those chewed wires look like the problem but it looks like it going to take an electrician to fix them.l. i dont kno :-(
Old 08-21-2006, 01:02 PM
wrightz28's Avatar
Those wires are the IAC -idle air control and TPS, throttle position sensor, and without either, things will not work correctly.
