| Engine intakes, exhaust, turbos, nitrous. |
What Capacity
What capacity are the p11 primera injectors? can a run safe with 5 psi of boost?
1998 PRIMERA GX 10.1 CR Chile. |
I believe they are about 260cc, which will probably be OK for low boost applications. For higher boost levels though, you will need at least 370cc units.
Owner of Primeraweb, and a 1997 Nissan Primera SRi driver |
The stock injectors should be good for about 6psi, once you get in the area of 8+ you should upgrade.
THANKS
Re: THANKS
They are 259cc (yeah, I know, what's 1cc?, but just for the record....)
My understanding is that at around 200 bhp you are getting dangerously close to the limit of these injectors. I think you would be wise to switch to the 370cc injectors.
George Roffe Houston, Texas USA 00 328i 91 SE-R (well modded) 84 944 SCCA ITS race car under construction "I fear all we have done is to awaken a sleeping giant and filled him with a great resolve" -- Admiral Yamamoto, December 7, 1941 |
True, at 200hp you should switch them, but you surely arent getting 200hp off of 5 or 6psi are you??
From what I've seen 6psi would only put you to about 180whp. |
You might be able to get away with it, but I wouldn't risk my engine on it.
If you reach the limits of the stock injectors then they simply won't flow any more fuel and subsequently the engine will run lean won't it? Surely this would stick out like a sore thumb on a dyno, especially as it would probably pink slightly under load. Or will the problems of inadequate injectors be somewhat more terminal than that, like misfiring or cutting out under power?
On a side note, am I right in thinking that in order to use 370cc injectors you MUST get a remapped ECU, else things will start to go very funny indeed?
it can be regulated with the apex´i s-afc or you have to reprogram the ecu? (370 cc injectors)
Running lean on a turbo engine is a receipe for disaster. You don't want to run out of injector.
I'm not an expert on this but it's what I've read and I'm taking if from my admitedly flakey memory. So if I missed anything i'm sure someone will clean it up for me. |
I have read that a fuel presure raiser can help any info?
OK - at least I know what really happens when you reach the limits of the injectors... thanks
