Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-06-2006, 07:26 PM
copcarcrzy copcarcrzy is offline
Rear Window Defroster
1st How long should the RW defroster run to do the job ???
2nd . How do you test to make sure the lines work all the way across, ive read it some where but cant find it.
Old 08-06-2006, 07:35 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Rear Window Defroster
#1, depends on how cold the window is... Usually within the first few minutes.
#2, I never did try to figure this out, but on my old Grand Am the good lines defrosted and the bad ones didn't - this caused an interesting pattern on the back window for the few times I used it!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-06-2006, 10:05 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
1) I've found with all the GM vehicles I've owned, the defroster is on a timer. It goes off at a pre-determined time, usually it seems within a 5 to 10 minute range.
2) I pretty much agree with silicon's post above. If you discover an area that is not defrosting the window, follow the "defrost line'' and look for any breaks in the line. That is what is causing the line not to defrost that part of the window. There are repair kits on the market to fix the break(s) in the line to restore continuity, I'm not sure how well they work as I've never used one.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
