Old 08-05-2006, 04:39 PM
shab_xp shab_xp is offline
How does your power steering feel?
Mine works fine in all, but I can feel some vibration when the speed is high. Is that normal to Camaro, or I need to service the power steering?
Old 08-05-2006, 05:47 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: How does your power steering feel?
look more to your tire balance and wheel alignment.
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 08-05-2006, 09:29 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
What year camaro?. Might also want to check the condition of your rag joint.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 08-06-2006, 08:45 PM
Thanks for the replies!
Mine is 96 RS. 100K. I just have the tire changed, so the balance should be good. I do not know if Tires Plus check the alignment though.
Can you give me more detail about the rag joint?
Old 08-06-2006, 08:51 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Usually tire places charge extra for an alignment, so unless you requested it or if it's on your receipt, odds are they didnt.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 08-06-2006, 09:34 PM
FormulaLT1's Avatar
Fight the powwa!!!
Rag joint is the hard rubber used on pre 98 steering linkages and with time and heat exposure can stretch and crack or even rip. Which causes alot of play in the steering (a real loose feel) and can lead to you have to keep the wheel in another position besides the 12 O'clock to keep the vehicle straight but the other suggestions are very likely as well.
Old 08-07-2006, 09:09 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
They may have not put the weights on securely and you lost one
seen that.
Also, I would check my lugs, you never know
Old 08-07-2006, 10:56 AM
Nate355RS's Avatar
Nate355RS Nate355RS is offline
Wright's got the right idea with checking all the simple things that could cause a vibration, make sure you do that before going after the more complicated stuff.
You've probably already checked, but make sure your tire pressure is where it should be on all four tires.
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
Old 08-09-2006, 07:33 PM
Hi guys,
thanks for your reply.
I checked the tire pressure, just did a balance for all of the wheels. But the problem still exists. The car begins to vibrate when the speed is above 50 MPH. I can feel obvious vibrating from the steering wheel.
I tested the drive shaft by downshifting, it seems that drive shaft is good too (When I revivied the shaft at low gear, the car was smoothy). I pushed the left front and right front, the springs also works fine.
Really confused.
Old 08-10-2006, 01:02 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
like power steering? i dunno
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 08-10-2006, 08:34 AM
Nate355RS's Avatar
I think your drive shaft might be out of balance. How fast your driveshaft moves depends on how fast the rear tires are spinning, not how fast the engine is spinning. That was a good idea to downshift to try to narrow down the problem, you just had it a little backwards. If you get a vibration at a certain RPM than it's engine/trans related, if you get a vibration at a certain speed it suspension/chasis related. So if you got up to speed and down shifted, the drive shaft would be spinning the same rate as if you were in overdrive. Hope this helps and good luck with finding the problem!
Old 08-10-2006, 08:43 AM
Thanks for your reply. I think you are right. When I downshifted, the spin of the drive shaft also slowed down. Because the shaft is connected to the transmission instead of the engine. It only shows the vibration is not from the engine.
BTW, I heard that chevy dealers cure vibration by replacing the drive shaft with an aluminum one. Does anyone know if a one piece aluminum drive shaft will fit my 2-piece drive shaft (mine is a V6 3.8 L).
Old 08-10-2006, 08:53 AM
FormulaLT1's Avatar
Fight the powwa!!!
Yes it will fit in perfectly and also help eliminate some weight from the drivetrain which will help performance wise. If you look in our classified section a member is actually even selling a Aluminium driveshaft at a very good price.
Old 08-10-2006, 04:26 PM
Hi F1,
Thanks. I did not find the shaft you mentioned.
BTW, are all of the shafts the same in length. I found that some people are selling Camaro driveshaft. They all said they fit 82-02 Camaro, however, the length was 44 inch from one of the seller and 41 inch from the other.
Old 08-10-2006, 04:29 PM
FormulaLT1's Avatar
Fight the powwa!!!
http://www.automotiveforums.com/vbul...d.php?t=597457 and yes they all fit each other from 82 - 02
