Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 08-03-2006, 07:55 AM
ccramair ccramair is offline
front wheel bearing
Does anyone know the steps in replacing front wheel bearings for a 2005 Chevy Impala. How hard is it and do I need special tools. Non ABS system
Old 08-04-2006, 12:13 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: front wheel bearing
Welcome to AF.
For special tools you will need a torque wrench. The axle nut will be torqued to someweheres around 150 - 180 ft-lbs depending on what the hub manufacturer or GM specifies. 36mm socket and breaker bar to remove the axle nut. And possibly a hub puller to get it off the spindle. For rest like brakes (caliper and bracket) and the hub bolts just standard metric sockets with 3/8" drive ratchet and extensions. Also, when completed the wheel nuts should be torqued to 100 ft-lbs.
Timeslip 08/12/06
AF Community Guidelines
