Old 08-02-2006, 07:38 PM
redstang423's Avatar
redstang423 redstang423 is offline
Mold Lines
After a several month hiatus from both modeling and this board, I've finally restarted my Tamiya 350Z that I had to strip the paint from. Before I prime it once again, I was curious how the mold lines will effect the final paint. I have sanded them down to the point where you can't feel them at all - smooth if you run your fingernail across the line - but you the lines are still visible. Will they still be visible once I prime and put the color coats down?
Jeff
In Progess: Corvette C5R (95%), 1995 Corvette ZR-1 (97%), 1968 Shelby GT500 (15%), Porsche 911 Slantnose (99%), Nissan 350Z track (80%)
To Be Started: Ferrari F50, Porsche 911 GT3, Mitsubishi GT0/3000GT
Recently Finished: 1999 Ford SVT Lightning
liveSTRONG
Old 08-02-2006, 08:08 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Mold Lines
Traces of mold lines are often still visible in bare plastic even after they have been completely removed from the surface. This is mostly due to the flow patterns of the molten plastic when the body was molded. They will likely be completely invisible when you prime (they will be invisible if youve removed them from the surface). This is part of why primer is a necessary step- because it allows you to evaluate the quality of the surface without illusions created by the bare plastic.
PHOTOBUCKET SUCKS
Old 08-03-2006, 10:35 AM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
Re: Mold Lines
However this will not garuntee that they won't show up when color is applied. I find that using a sealer over the primer virtually eliminates any ghosting.
Freakin' Groovin"
Old 08-03-2006, 06:14 PM
Re: Mold Lines
Excellent, thanks for your help!
Jeff
liveSTRONG
Old 08-04-2006, 07:44 PM
oregon3 oregon3 is offline
Re: Mold Lines
What type of sealer can be applied over Tamiya grey or white primer?
