Old 08-16-2002, 05:22 PM
jusg19 jusg19 is offline
HELP my rear disc swap has gone so bad
ok, i finally got it back together. crx si rear on a civic hatch dx. but i went to get an alignment and the front was good, the drivers back was fine, but the passenger rear had a toe of -2.56 degrees and they fixed it to -1.93 degrees. the spec is +.04-+.16 degrees. the only thing i did different on the right than left, was the front arm on the trailing arm that connects to the car and controls the toe adjustment, on the left i used the crx one and on the right my stock hatch one because i didn't have the crx one for that side. (if anyone has one can you post quickly please.)
I called a place that does disc swaps on hondas and they said i should just put back my upper and lower arms from the hatch and take off the crx ones off. so i'm trying to decide weather to put those 2 arms on, which i have. or go hunt for a crx front arm.
AVOID DOING A SWAP BY AN SI!!!!! (never thought i'd say that)
Old 08-16-2002, 05:26 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
maybe your problem is a bent trailing arm....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 08-16-2002, 08:55 PM
the arm isn't bent, i thought that too but its not. i compared it with the one i took off and it has all the same shapes.
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 12:29 PM
my ECM or ECU has gone bad boosting20psi Off-Topic 1 01-07-2004 02:23 PM
96 Camry exhaust has gone bad htsunami Camry/Camry Hybrid/Vista 1 12-20-2003 04:32 AM
Rear Disc Swap is finished! FourthGenHatch '88 - '91 Civic | CRX | Wagon | Shuttlee 9 10-01-2002 10:19 PM
Anyone else doing rear disc swap soon? FourthGenHatch '88 - '91 Civic | CRX | Wagon | Shuttlee 5 09-19-2002 09:57 PM
