Old 07-31-2006, 02:29 PM
wht-tail wht-tail is offline
Problems with 2000 GTP (Questions)
Just relaced the ignition module and also the crankshaft sensor and that fixed the TCS light problem and the engine shutting down but I still have the spitting and sputtering during light to moderate acceleration. The car has 120,000 miles and up to now has been almost trouble free. Next I plan on changing out the plugs and wires and the fuel filter. How difficult is it to remove the back three plugs? What type of plugs and wires should I buy?
Any comments and or suggestions would be greatly appreciated.
Thanks
Old 07-31-2006, 02:52 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Problems with 2000 GTP (Questions)
If you are stock:
Plugs = AC Delco 41-101 Iridium. Gap .060
Wires = AC Delco Premium Silicone 7mm
Try the plugs, wires and fuel filter first. If that doesn't work check into a possible flaky MAF sensor.
Rear plugs are tedious but can be replaced with the right spark plug tools. No need to loosen dogbone mounts and shift engine.
Timeslip 08/12/06
AF Community Guidelines
Old 07-31-2006, 02:57 PM
wlkjr's Avatar
wlkjr wlkjr is offline
wht-tail you have a PM.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 08-01-2006, 03:19 PM
bnaylor Would It benefit me in any way to go to a larger size wire. Also thanks for you previous response. vbmenu_register("postmenu_4238010", true);
Old 08-01-2006, 03:41 PM
BNaylor's Avatar
Ignition wires are really a matter of personal preference and any advantage over another is really hard to say. The 7mm AC Delcos are great wires but boring. The next wire of choice is the Taylor Spiro Pro 8mm wires. Reasonable cost and selection on colors.
Now, I use MSD 8.5mm on my GTP. Not that they are any better than the other wires. I have not documented any performance gain. But the 8.5mm MSD do have the least resistance per foot of any of the wires. I have the red and they match the red MSD Blaster coils. Looks nice when you pop the hood.
Timeslip 08/12/06
