Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 08-16-2002, 10:26 AM
nabilsx nabilsx is offline
Question 745 technical info required.
A friend of mine has a BMW E21 with a 745i turbo engine underhood.
since he is totally nuts, he raised the boost from 0.5bar stock to
1.2bar.
he got an adjustable FPR from a Lancia Delta HF intergral, and he is
using the 745i stock IC, the ECU is 012, I guess coz the rev limiter on
the 013 is at 5500RPM while the 012 revs till 6500RPM.
as expected with such boost and stock injectors the car is running so
lean and even is cracking cylinder head at the exhaust valve from 2nd
to 5th combustion chamber. and the sparks are white in color "that is
how lean its running".
anyway we got a piggyback system from perfectpower www.perfectpower.com
its the SMT5-I model, it controls ignition timing, fueling and extra
injectors.
but to make it work on the bimmer some data must be entered in a
specific screen on the SMT software.
and this is where I need ur help, I would really appreciate if u can
provide me with that, and I am trully thankfull for any help and for ur
time and effort.
1- do u know how many teeth per turn "including missing teeth if any"?
2- how many teeth per firing.?
3- the MAF sensor what is the max and min. voltage that it reads?
4- does it have missing teeth and is it 1 or 2 missing teeth if any?
5- ignition input polarity, is it positive or negative? what about
output polarity?
6- does it have Bipolar (magnetic) input?
thanx.
Need technical info for 740IL please. Rick88 7 Series 2 12-15-2010 09:49 AM
Technical help required please!! itiejim 156 0 10-25-2005 01:43 PM
technical info regarding emissions failure drmeyers2001 Prelude 0 09-08-2004 08:57 PM
Any manual/technical info on 2k malibu on inet? sumone Malibu 2 02-20-2004 01:00 PM
