Go Back   Automotive Forums Car Chat > Rolls Royce > Silver Series
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-29-2006, 02:14 PM
veshragh veshragh is offline
Need help with 1981 Silve Sprit ingition
Car does not produce ignition spark when cranking the engin, but when the switch is being turned off it produces one spark.
It has gas, new injectors, plugs, clean cap and rotor. I cahneged all to fix a missing problem none fixed it and now no spark when cranking.
Where is the location of the ignition Amp control module?
If the modul is bad can i find after market repalcemet or I have to by exact unit.
If other repalcement available any recomendation? Can i buy a conversion Kit? Which Conversion Kit will work with 1981 V8 6.7L distributor modul?
I will send a token of appriciation to whom his helping direction would fix my car.
Thanks,
Vahid
Old 04-03-2008, 11:19 AM
Philspirit85 Philspirit85 is offline
Re: Need help with 1981 Silve Sprit ingition
Have you changed to coil? if there is no spark, I would start there and you can get a coil for under $50. If you have a timing light, put the clamp on the ignition coil lead, crank the engine and see if it lights the timing light. if it does not as I suspect it wont then I would get a new coil.
Old 04-03-2008, 11:42 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Please read the Community Guidelines as it refers to resurrecting old posts. Start a new thread if you have new info to add rather than bring up an old post. Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
