Old 08-15-2002, 11:30 AM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
B20 swap questions
ok. I've decided to swap in the b20b into my 97 coupe. i should be able to afford the motor with my income tax next year. I want to, between now and then get all of the odds and ends. The ultimate goal of this swap is to have a b20b turbo setup. so keep this in mind. first off, what all is needed for this swap. which ecu, axles, etc......i want to know everything (anyone know of a site detailing this swap)
as for the transmission i havn't decided whether i want to start with the GSR and swap to the ls tranny when i turbo or just go with the ls from the get go.
any and all information would be greatly appreciated
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 05-14-2004, 01:30 PM
aipsyko aipsyko is offline
Send a message via ICQ to aipsyko Send a message via AIM to aipsyko
crv swap into a civic
dude. this swap is prety streight forward. there are a few things that you may need to remember though. first off you will need to set up a vtec by-pass relay. second of all you will need to convert your speedometer cable for your transmission to an LS plug from the harness. you will also need to upgrade the fuse under your dash board to a 10 or 15 amp fuse for the ignition/alternator/speed sensor because you will pop the fuse. you will need to use your stock harness. you will be able to use ls drive shafts and you will also need to by the nock sensor will need to be converted and there is no crank sensor on a dohc motor when there is one on a single cam motor. if you have any other questions e-mail me at [email protected]
2.7 to 3.2 Engine Swap Question ddennis002 Intrepid 1 12-01-2010 07:15 AM
B16 swap questions, wiht my B20 of course. 94tegRS Let's get Technical! 4 02-26-2004 11:38 PM
b20 swap question 90teg Integra 5 10-01-2003 01:30 AM
A Newbie's question about the B20 swap chewiejdh Engineering/ Technical 6 11-21-2002 03:50 AM
B20 swap tech Q JdmImportz '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 05-05-2002 01:33 AM
