Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 07-25-2006, 02:42 PM
DONGKEYILPS DONGKEYILPS is offline
Need help with swap(d15b)
HEY I JUST FINISHED MY MOTOR SWAP I DID TRANNY CLUTH AND ENGINE AND I GO TO PLUG EVERY THING UP AND AS IM CONNECTING THE BATTERY THE RED WIRE STARTS TO SPARK AND THEN IT JUST STOPS SO I GO AND TURN ON THE ENGINE AND I GET NOTHING NO POWER, I TURN THE KEY AND NONE OF THE LIGHTS WORK SO NO POWER IS RUNNING IN THE WHOLE CAR AND I CHECKED THE FUSE BOX TO SEE MABYE IF I POPPED A FUSE SURE ENOUGH IT DID SO I CONNECT A WIRE WHERE THE FUSE BLEW AND I GET THE SAME REACTION AND STILL HAVE NO POWER, I WAS JUST WONDERING IF MABYE ANYBODY KNOWS WATS GOING ON, OH AND I CHECKED EVERY PLUG AND THE GROUNDS AND EVERYTHING ELSE IS FINE…
Old 07-25-2006, 07:32 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Need help with swap(d15b)
And you shouldn't be hooking up the positive last, the negative always comes off first and goes on last. You probably popped your battery fuse. Check that. Also, other fuses might have gone before the battery fuse went so check them all.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
