Old 07-22-2006, 07:15 PM
teamanila's Avatar
teamanila teamanila is offline
Question Putty problem.
Hello fellow modelers.
I have a problem with a project that I'm currently doing. I'm using Mr. White Putty to fill in panel lines. I sanded it down and it looks perfect, but after awhile the panel lines started to show again. How long do I have to leave the putty on before sanding it down? Is there a better way to fill in panel lines? Feedback please!
Cheers!
Old 07-22-2006, 07:49 PM
freakray freakray is offline
AF Modelrater
Re: Putty problem.
Some types of putty shrink as they dry, it sounds like you have one of those, if that is the case it doesn't matter how long you wait it will still shrink slightly.
In this case it's a safer bet to build up several thin layers of putty.
Place some more putty over the area and allow a day for it to cure, then sand it smooth. You may have to do this more than once to fully fill the panel line.
Don't forget to prime over the putty too to check for an even surface.
AF User Guidelines
Old 07-22-2006, 11:11 PM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: Putty problem.
There are 2 ways to fix this.
1: What freakray said.
2. If the lines are just ghost lines, then you can use Mr. Surfacer 500 or someother filler primer. Spray it on.. then sand it down after 7 hours.
It sounds that the putty isn't fully cured when you start sanding.. and Mr. White putty is a 1 part putty so.. it cures by evaporating it's solvents. Like freakray said you should give at least 24 hours to be sure. Use a dehydrator if you have 1. The thicker the putty the longer it will take for it to cure.
Here is a link that might help you Body Mods How To by GTmike400
HTH
Steve
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 07-22-2006, 11:49 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
Re: Putty problem.
If you have a big panel line, just use styrene stripes or rods to fill the gap. It sands easily and doesn't shrink, and takes paint just like the rest of the body.
Old 07-23-2006, 10:32 AM
teamanila's Avatar
Re: Putty problem.
Thank you for all the suggestions. I will try and leave the puttied surface to cure longer before sanding it down. I was thinking of using the two part epoxy putty from tamiya to redo the panel lines, though it applies too thick. Anyway, I'll see how this second time around will come out. Thanks!
