Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-17-2006, 12:57 AM
joelmar10 joelmar10 is offline
A/C different temps at different vents
I have a 2002. Replaced the condenser with the leak at the lower passenger side bracket (go figure) last winter. Had to top of the r134a today and the leftmost two vents blow warmer than the center vent and the passenger vents (no rear air). cabin filters were pulled many moons ago. hissing sound from inside the dash went away once I got the refrigerant back up to pressure, but still there is a temp differential in the vents. what's up with that? any ideas are appreciated. btw 168k and already paid to see a few of the venture weak spots (condenser, intake gasket, frumpy rear drums making me chew up rotors). still love my venture.
Old 07-18-2006, 10:02 PM
Re: A/C different temps at different vents
Anybody know how the blenders work before I start tearing my dash apart? A link would be appreciated. thanks
Old 07-20-2006, 07:46 PM
xt477 xt477 is offline
Sorry I cant help...yet anyway
Just noticed mine doing the same thing yesterday and am planning on pulling it apart this weekend.
Will let you know what/if I find anything.
Well Joel I just replaced my compressor and all is right with the world. Ac wise anyway. I assume the old compressor didnt develop enough pressure/vacuum.
Old 07-20-2006, 08:18 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
First thing is a proper charge.
Wal Mart DEATH KITS
You cannot properly and safely recharge an air condition system with them.
The one side stop and go gauge does not tell you what your system is doing or is over charged or undercharged.
A overcharged or malfunction air condition system can reach over 500 lbs of pressure.
Enough to blow up that can or system and freeze you at first and the burn you or blind you and if any propane /butane in there blow and light you up.
The stop leak crap and who knows what kind of oil in the kits there will stop your system for sure.
Just like pouring super glue in it.
And some kits even contain freon with a butane mixer.
Good for a big blast.
If you are going to do it do it right and safe.
Here is what you need to start with.
http://www.ackits.com/merchant2/merc...uct_Code=66773
In the older days you could just throw in a can and go.
But over the years just adding freon is getting harder to do.
Newer systems have to have the correct amount of freon down to the ounces.
Most will need pumped down and vacuumed down and the right and amount of oil and a set amount freon charge installed to get the air to cool right and the system to last.
If an air condition is low there is usually a leak that needs fixed and also a lose of lubricating oil from system.
Also air and moisture enters a low system
If you are going to try to do it get the proper type air condition gauge set with the low and high side gauges.
Hook up the gauges and get a reading with compressor running at idle and at 2000 rpm on the high and low side.
Post back pressure reading and we can help you.
MT
MT
Old 05-29-2007, 08:43 PM
edsut edsut is offline
Hey! My 1999 Venture is now "warm" on the driver side and "cold" on the passenger side. Both of the filters are clean, and I do get air pressure out of both sides (just different temperature). It may be my imagination, but it seems like the left side is not only warm, but also not as much air flow.
Anyone ever figure out what this problem was? It's May29th so I sure would like to get my AC back before it gets hot!!!
Thanks for any help or suggestions!!
Ed
Old 05-29-2007, 09:27 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
In this situation, please start a new thread, rather than bring up nearly one year old threads. It only clutters up the message board more. Here are the Community Guidelines concerning proper posting:
" AF Guidelines to Posting in Forums"
Thread closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
