Old 08-11-2002, 01:33 AM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
Are Door Panels Interchangeable?
Will the door pannels from a 88-89 civic fit a 90-91? i am asking this because i know the window is smaller on the 90-91.... but when i get my 4pt. harness i am gonna take out the seatbelts out of the door, but i dont want the hole there.... So, i was gonna take door pannels off a 88-89 and put em on because thee will be no holes for the seatbelt....
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 08-11-2002, 02:08 AM
1990civic's Avatar
1990civic 1990civic is offline
No They Are Not The Same!!!! Also If You Get The Door Panels Off Of A 90-91 (Seatbelts In Pillar) This Would Work Also!!!!!
Old 08-11-2002, 02:24 AM
MyFirst4G's Avatar
Yea, i heard about that, the 90-91 civic's in Canada have the belt on the pillar, but those door panels fit the US panels....... Now, where can i get a set of canadian door panels?
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 08-11-2002, 01:05 PM
1990civic's Avatar
Truth Is I Really Don't Know About The Whole Canada=Pillar, US=Door!!! My Hatchback Is Made In Canada, And It Has The Seatbelts In The Door!!!! I Would Just Check At Your Local Salvage Yard They Probaly Carry Both Door Panels!! On MONDAY Ill Check Around Here To See If You Can Get The Door Panels!
Old 08-11-2002, 01:43 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
Okay yes and no.... i did this. I have a base model 90 that had the door mounted belts, i put 4points in and wannted to change door panels. A buddy of mine sent me Candian Si door panels.... They are the same shape and will fit fine..... there are only two things that need to be changed..... one is not all of the tabs that pop into the doors are in the same spots.... i just drilled new holes. second is that on the top rear of the panles the Si ones are longer.
this was my old door panel:
this was the new Canadian Si door panel
see the difference??
if you have anymore questions i can post some more pics ofhte new ones on my car and what they look like.
edit: sorry for the big pics...
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 08-11-2002, 02:05 PM
civicf/x civicf/x is offline
door panels
Yeah, man I'm from canada and I've only seen the door mounted seatbelts in this forum and thought they were crazy. I've never seen them before, any wrecker in Canada would for sure have what your looking for. I've owned both a 88-89 and now a 90-91 and neither had the door mounted seatbelts.
Old 08-11-2002, 08:12 PM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
ya i live in canada and have never seen that untill i saw this fourm. were could i find a set of of the door seat belts?
Old 08-12-2002, 05:45 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Hey travis. I was thinking about doing the same thing after I get some harnesses. How did you modify the panels to fit? Did you just cut the corner to match?
Old 08-12-2002, 07:29 PM
yep..took a hack saw and carefully cut to match.
Old 08-12-2002, 07:45 PM
ci5ic's Avatar
The vinyl didn't peel back on you at all?
1997 Grand Prix 2 door window problem olopezm Grand Prix 4 10-30-2010 09:20 PM
96 door panel mikeburrit01 1st Gen 95-99 3 04-24-2010 03:26 PM
Please help - Can't open door chuck_T Auto Collision Network 2 10-26-2009 09:04 PM
How To: Remove Door Panel LifeIsPain Montana/Montana SV6 1 03-21-2009 07:08 PM
Interchangeable Door Panels?(power windows) CharmCity '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 06-13-2002 10:22 AM
