Old 07-12-2006, 11:59 AM
95firebird 95firebird is offline
what is it called
i what a question my car has been leakink old so i had my auto teacher look at it he says it leaking where the distributor use to go on theses car does any one no what that is called he did not what it was called some teacher
Old 07-12-2006, 03:23 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: what is it called
3.4L correct? If so, then the distributor on the 2.8's and 3.1's used to be located right behind the intake manifold. So if your lucky, then it would be the back of your intake manifold leaking.. but in the worst case scenerio, it would be your rear main seal.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 07-12-2006, 08:23 PM
no that it called like oil drive shaft or somthing like that what ever it leaking will cost less then the rear main oil seal will to be fixed
