Old 07-10-2006, 10:17 PM
Alexxn 00 Si Alexxn 00 Si is offline
Help car won't start - no spark
92 Civic LX 1.5. Just up and died one day. Checked for spark - none. Car sat for 2 days, started up, drove, shut it off and won't start now, still no spark. Installed a remanufactured distributor, nope still won't start....no spark....
Anyone have any clue what I should do next ??
Much appreciated !!!
2005 Chevrolet Silverado 2500HD Ext cab
Old 07-11-2006, 09:52 PM
Re: Help car won't start - no spark
So I did a test here...I connected the alligator clip of a test light to the positive post on the battery and the test light tip to the negative side of the coil...had a friend crank the engine over...shouldn't the test light flash on and off if all is well ? It stayed dark....igniter maybe ???
Help !
Old 07-11-2006, 11:01 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
If you just replaced the Dizzy then that's probably not the cause of the problem. Have you checked to see if your plug wires are good or if the plugs are good? If your wires are good then you need to check your spark by taking the end of the plug wire out at the plug end and hold it close to a metal part of the engine while a friend tries to crank it. If you see sparks then your ignitor is good. You need to note when you try that, whether or not the spark is steady or if it sparks at intervals.
AF COMMUNITY GUIDELINES
Old 07-12-2006, 05:54 AM
I replaced the distributor with a remanufactured one - so not alot of faith there really.....before I did any of this I tried pulling a couple of spark plug wires to check for spark - none.....I am back to the original distributor now - and did all of the tests with this one - NOTE - the original distributor is only a year old....
Thanks !
Old 07-12-2006, 11:06 PM
I would start looking into other problems. It's very unlikely that you would have two bad ignitors or that both dizzys were bad enough to keep you from getting spark. Just because the newer one is remaned doesn't mean it isn't trustworthy. I would check you're wiring to the Dizzy and make sure everything is good there first.
Old 07-13-2006, 03:42 PM
I am skeptical about the igniter myself but all of the tests I have been following in the Haynes manual are all pointing to the igniter at this point...I do have power going into the distributor and coil so I'm not sure what else can be wrong in the wiring....
Old 07-18-2006, 09:28 AM
So what a surprise it wasn't the igniter....I'm totally in the dark now...everything else looks good, someone mentioned a Main Relay somewhere on another board.......
Old 07-21-2006, 10:47 AM
GEESERTEG's Avatar
GEESERTEG GEESERTEG is offline
Have you checked all the voltages going in and out of the dizzy. What I mean is that you need to verify that your position sensors on the crank and cam are feeding back to the dizzy. If not it will not get the "thumbs up" from the ecu to function. I recommend you buying a Haynes type sevice manual. It should go more into detail of the whole operation. You can also try hitting my website up too. Good luck... I know how these problems can be.
http://www.HondaFactor.com ---- Honda/Acura Enthusiast Community
07 Habanero Red Civ Si -- baby's new baby.
94 Honda CivicEX -- 200,000mi ---SOLD
98 Acura Integra GSR --SSBP-- Tein H-techs/Tokico Blues/AEM SRI/More SOON
02 Fud Expedition 5.4 EB
