Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 07-09-2006, 02:34 PM
cierradude cierradude is offline
'87 Delta Idle issue
My 1987 Delta 88 with a 3.8l V-6 is starting to act up when starting. It will not idle, but when I give it gas it will run. Any suggestions?
It just started doing this today. although it has had a rough idle.
Thanks!
Bob:
Old 07-09-2006, 02:53 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: '87 Delta Idle issue
Any reasons why you posted in the Cutlass subforum? You may get a better response at the Eighty Eight subforum.
Thread moved to Olds Eighty Eight.
Timeslip 08/12/06
AF Community Guidelines
Old 07-09-2006, 09:05 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Any trouble codes? I vote that you need new plugs (AC Delco ONLY!) and wires (don't get cheapies). Or just a basic tune-up. Filters, O2 sensor, plugs, wires, and a bottle of injector cleaner (chevron techron or lucas would fix you up niceley).
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 07-10-2006, 02:36 AM
The plugs and filters are brand new. Wires are in good shape. I will check to make sure the plugs are tight. I am thinking a bad injector since it will not idle. ??? Thank You!
Old 07-10-2006, 08:20 PM
Alibi's Avatar
Umm...you didn't buy Bosch plugs by any chance, did you??? If you did...then that would be your problem. Did you gap them correctly?
-Eric
Old 07-10-2006, 09:39 PM
No, I use only AC plugs in this car. Turns out it was the AIC valve.
Thanks for the suggestions, Bob
