Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-07-2006, 06:52 PM
paul_cowan paul_cowan is offline
Service vehicle light on
I have Service Vehicle Soon light on in my 2000 Alero for no good reason. It has been on for over a year. Maintenence is all up, standard code readers make no sense of it and there is no method in the owner's manual or in Haynes manual to reset it. The Olds dealer thought maybe it was a computer glitch and Offered to replace the computer $350. A more reliable mechanic couldn't make sense of it either. It passes California smog test OK. Isn't there a law that says that vehicle information must be public after a certain time? this is not Service Engine light, but the Service Vehicle Soon light. What does it mean? Is there a recall for it? Can it be reset? There must be others out there that have had this problem.
Old 07-07-2006, 07:05 PM
jd-autotech jd-autotech is offline
Re: Service vehicle light on
are ther any other lights on abs, trac off light? cause if so its normal or believe it or not it could just have a light bulb out somewhere on the car
Old 07-07-2006, 07:30 PM
maxwedge maxwedge is offline
A990 racer
Question Re: Service vehicle light on
First welcome to AF, did you read the owners's manual, is it possible this is a service reminder lite and if so the reset procedure would be outlined in the manual. I am sure one of the guys more familiar with this model will chime in here.
Old 07-07-2006, 07:37 PM
BNaylor's Avatar
BNaylor BNaylor is offline
The SVS light - Service Vehicle Soon indicates a fault with the safety systems of the vehicle and should give off an annoying chime if there is an actual failure. On an Alero a few things that can give a SVS light are Daytime Running Lights (DRL) (possible defective DRL module) and/or the auto headlight system/light control malfunctioning. Sometimes a burned out headlamp or brake lights may give a SVS but I've never seen that happen on an Alero but you never know. When you replace the defective part the light should extinguish.
Even a bad hub bearing/wheel sensor can give a SVS light but it is normally accompanied by an ABS and Trac off light.
Are the DRL and auto headlamps working properly?
Timeslip 08/12/06
AF Community Guidelines
Old 07-08-2006, 08:49 PM
Only the Service Vehicle soon light is on. I did find and replace all defective bulbs, but it's still there. Do I have to do something to reset it?
Old 07-20-2006, 01:00 PM
tomeopaste tomeopaste is offline
Send a message via AIM to tomeopaste
Hey guys,
I've got the same SVS light on in my '99. It is on due to some sort of problem with the automatic light system. Since the light came on I have had to turn on my lights manually, the headlights seem to come on fine by themselves but my dash lights and tail-lights do not come on automatically. Does anyone now anything about this, how to go about fixing it, or if it's really worth caring about at all?
Old 04-28-2007, 02:03 PM
17dewalt 17dewalt is offline
change the o2 sensors and the light should go out
Old 04-28-2007, 02:11 PM
Re: surging problem
My 2000 alero surges between 2000 and 3000 rpm. what can i do to fix this.
Old 04-28-2007, 09:25 PM
BNaylor's Avatar
Re: surging problem
Sorry but please check the date and do not resurrect old threads. Thread closed.
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
Timeslip 08/12/06
Closed Thread
