Old 08-08-2002, 11:42 PM
branman_crx_guy's Avatar
branman_crx_guy branman_crx_guy is offline
Send a message via AIM to branman_crx_guy Send a message via Yahoo to branman_crx_guy
Hood latch problem
Hey, I'm trying to fix all my little problems and i just figured I would put this one up. When I unlock my hood latch, it doesnt come back out, and without it out all that keeps my hood closed is the safety, and I dont trust that. I can get the latch to "lock" again (not sure on the right terminology) but I gotta beat on a bolt next to the latch with a hammer, which makes vibrations which cause the latch to come out. I already took it out and soaked it in WD-40, that did nothing, anymore ideas? Should I just try to find a new one? If so, where should I go and how hard will it be to replace? Thanx in advance :frog:
Born 2/19/85: Thats right ladies, the BMan is Legal!! ;-)
Totallin My 89 CRX Si: +$2700
Buyin It Back From Insurance: -$50
Buying a 90 CRX Si: -$2200
Gettin to start over with more money and knowing i screwed insurance w/out trying: Priceless
It doesn't matter if you win by an inch or.........wait, thats been said already. On the road of life there are passengers and......no, thats been done too. Dang, all the good sayings have already been said, ohwell.
-BMan original
Old 08-09-2002, 12:12 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Your question is really confusing... Are you saying that when you pull on the hood-release, it doesn't actually release the hood?
If that's the case, open up your hood, and look at the bottom latch (by the radiator). You will see 2 bolts (10mm I think). If you loosen these bolts, you can move the lower latch around inside the hole a little bit. Then re-tighten the bolts and see how the hood matches up... After a couple trys, you should be able to get it right.
Old 08-09-2002, 12:41 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Worse comes to worse you could go to a junkyard and get another one.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-09-2002, 09:47 AM
Yeah it is confusing, let me try to explain it better. Its not the hood-release, that works fine, its the little disc inside the hood latch which releases the hood thats the problem. It'll release the hood fine, but it stays in the release position, so the hood doesnt latch. Beating on the bolt near the latch vibrates the little metal disc inside the latch enough to make it come out. Thats my problem, hope its more understandable
-BMan original
Old 08-09-2002, 03:18 PM
ci5ic's Avatar
OK, I understand now...
Have you tried any lube? Like some WD-40 or something... could be a bad cable also... might wanna pick up a whole new one at the JY.
Old 08-09-2002, 04:38 PM
I tried WD 40, so I guess Ill just go get one from a junkyard, thanx
-BMan original
01 Beetle - Hood Won't Unlatch mhalliar Beetle - New/New Beetle Convertible 1 12-17-2009 01:37 PM
Hood latch problem LXA Rodeo | Passport | MU 2 01-31-2009 06:17 PM
Bumpers & Hood Latch problems uH8THECHEVY Grand Cherokee | Grand Cherokee SRT8 0 03-07-2007 11:04 PM
Hood latch problems Poose22 Grand Prix 1 05-19-2004 11:36 AM
Hood Latch Problems l2ice rocketz '88 - '91 Civic | CRX | Wagon | Shuttlee 8 03-30-2003 08:47 PM
