Old 08-08-2002, 02:48 PM
1stealthciv1c 1stealthciv1c is offline
hood problem :-(
hey, I just installed my new hood on my car. First of all when it was done i noticed a big gap from the fender and the hood on one of the sides. :-( To top it all off. I now cant even pop the hood open. When i got in the car and pulled the lever to open it, it was loose and went all the way back and didnt even pop the hood. I have no way of opening the hood now. Can this be fixed at a dealer???? Will it be expensive to fix???
Old 08-08-2002, 03:25 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
just reach for the cable from under the hood and pull on it to open your hood. You should be able to just align and remount with no help from the dealer.
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 08-08-2002, 04:55 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
I had a similar problem when I installed my Cervini's fiberglass hood. I had to pull really hard on the hood release to get it to pop. Once you get your hood open, look at the latch that's near the radiator (not the one on the hood), and there are 2 bolts (10mm I think). If you loosen these bolts, you can adjust the position of the latch a little bit. Then tighten up the bolts and you'll be set...
Old 08-08-2002, 08:51 PM
hood
Thats just the thing. I cant pull on the hood release. ITs loose!!! I pulled it hard enough to where its stuck now. I can pull it back down. :-(
Lowered BMW problems... :-( Ashleyyy 3 Series 0 04-18-2010 12:30 AM
Horrible paint problem :-( patoffspyder Car Modeling 14 05-19-2006 11:09 AM
SO many problems :/ Ash95 Probe 2 10-25-2005 03:10 PM
Driver's Side Window Problem :-/ Yourtemptation85 S-10 3 08-07-2005 10:45 PM
Power Brakes Problem :-/ HELP! TheNakedCowboy1 Blazer 1 02-08-2004 06:21 PM
