Old 08-08-2002, 02:25 PM
NiGhtRider_RS NiGhtRider_RS is offline
Send a message via AIM to NiGhtRider_RS
Can i strap on a turbo?
I've got a 1991 camaro RS (305 TBI) and i want to know if i can put on a single turbo (big as i can) on my engine. I know it'll be a little hard on it, but other than normal wear-and-tear are there any other things that i should be aware of? Oh yea, also: what kind of turbo should i use? thanks -kyle
My car looks like nightrider. I'll finish this later...
Old 08-11-2002, 03:36 PM
custombuildinF-350 custombuildinF-350 is offline
Send a message via AIM to custombuildinF-350
if your goning to put the biggest turbo you can you are going to need to put in new set of piston and rings rings that can handle the power. if you want the full affect you should get new valves and valve springs. mabey a stronger cam that will withstand abuse throught your RMP range. but if your only going to put a little turbo on you should still think about new rings just to be safe. enjoy your ride:evillaugh
REV IT UP. DUMP THE CLUTCH. KICK IT SIDEWAYS. RIDE IT OUT.
Old 08-15-2002, 08:56 AM
Yea..good call. I should look in to some rings and such. Power is good:bandit:
Old 08-24-2002, 08:43 AM
blackbob's Avatar
blackbob blackbob is offline
Send a message via ICQ to blackbob Send a message via AIM to blackbob Send a message via MSN to blackbob Send a message via Yahoo to blackbob
Well
You shouldn't have a problem turboing the car as long as you do all o what the guy above suggested. You know heads,rings,injectors,ams,valves etc.. Now I hope you do understand since the car is N/A there might be some custom fabricating involved. Other then that prepare to go through the many problems that most people go through when turboing a car. But in theend it will be well worth it.
RogueRacing
"Dare to be different"
SHIFT_imagination
can a turbo from a daytona be put on a non-turbo laser 85laser Daytona 5 01-03-2005 05:54 PM
can i turbo it with grand natinal turbo? mazdaspeed_MX6 LeSabre 1 12-06-2004 08:33 PM
can i turbo a 92 cavvy? DJ_BigSkrilla Cavalier 20 06-06-2004 05:28 PM
Can I turbo my celica? branz99x Celica 4 05-19-2002 02:01 PM
can you turbo charge a 2000 civic ex auto? rendog24 Forced Induction 3 04-18-2002 02:31 PM
