Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-03-2006, 07:39 PM
pacman99 pacman99 is offline
2000 Integra making noises at high RPMs
Hey,
I'm driving a 5spd 2000 Integra GS with around 110k (km). I bought this car about a year ago and I was having this type of problem then too but I was assured by my mechanic that it wasn't that important and didn't need to be fixed just yet. He did say it would get worst later, which is what's happening now.
After a cold start (even if the car has been sitting outside for maybe 2-3 hours in 25C+ weather), my car will make rattling noises [doesn't matter if the clutch is pressed or not]. The sound appears to come directly from the hood. Before, after driving for about 15mins or so, the noise would go away. Now, the noise goes away after 15mins but if I shift at around 4000rpms or so, I start hearing the same noise. It's fine at >5000 rpms or <3500rpms. This noise also goes away after about 30mins of driving.
I just wanted to know if this is a huge problem in the making? I still have a warranty on this car (for another 2 years) so I wanted to make sure if something bad is in the works, I could perhaps get it covered under warranty?
I just got an oil change on the car too and usually get one after approx 3000-4000km or 3-4months, whichever comes first. I don't drive this car much, perhaps 5-10km daily on the weekdays.
If there's something I could check and report back, please let me know.
Thanks~
Old 07-06-2006, 11:30 PM
steffenst steffenst is offline
Re: 2000 Integra making noises at high RPMs
Honda's or Acura Don't perform that well in the winter. I have a 1990 integra and only have 105,000 miles. Try changing your fuel filter, spark plugs, air filter, PCV valve, and flushing your radiator. Yuor Belts could be going bad as well. If you drive your car every winter you are destine for major engine issues.
Old 07-06-2006, 11:40 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
If it's rattling when it's not warmed up it could be exhaust related. The heat-shield over my cat came loose and would rattle untill the exhaust warmed up and expanded, then it would stop...untill I ripped it off. Check to see if anything's loose.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 07-07-2006, 09:31 AM
GEESERTEG's Avatar
GEESERTEG GEESERTEG is offline
Check your heat sheilds around your header and cat. Many Hondas have an issue with the thin heat shields cracking at the bolts.
http://www.HondaFactor.com ---- Honda/Acura Enthusiast Community
07 Habanero Red Civ Si -- baby's new baby.
94 Honda CivicEX -- 200,000mi ---SOLD
98 Acura Integra GSR --SSBP-- Tein H-techs/Tokico Blues/AEM SRI/More SOON
02 Fud Expedition 5.4 EB
Old 07-14-2006, 04:04 PM
thx, it was the heat shield on the cat. It was loose and had someone weld it so it'd be firm and now the sound is gone.
BUT another problem came up after that. Now when I drive, the car is sluggish. It accelerates slower than before and at around 3000rpms, my car jumps a little (sort of like what happens when you're in a certain gear and you drop below 2000rpms) and starts picking up a bit faster. This never happened before. I shift at aroudn 3500-4000rpms normally.
Could it be a problem w/ the exhaust not letting out enough air or something?
Also, while I'm asking this question might as well ask this: I just had my A/C recharged and finally I get cold air hehe. Anyways now when the AC is on at level 2, the car tends to idle at around 500rpms and sometimes shakes. Is this normal?
Thanks again!
Old 08-06-2006, 12:35 PM
carlos integra carlos integra is offline
first open the hood and with your hand take the body throttle and acelerated the motor to listen the noise if the noise came upper dobble cam shafts is the valves nocking the pistons have too changes or take the car to acura shop to verify the problem correctly. good luck
Old 08-06-2006, 02:26 PM
yea it was the heat shield on the cat doing that again. I just got rid of this time. The noise is still there so I guess I should check the header.
Thanks~
Old 08-06-2006, 04:51 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
Dude I'm not trying to be an ass but that post is almost incoherent. Please please proof read your posts. We even have a spell check option. After you type everything just right click scroll down to check spelling and it will highlight and underline any incorrectly spelled words.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
