Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 07-01-2006, 11:20 PM
Tyrone 95SolSi Tyrone 95SolSi is offline
Send a message via AIM to Tyrone 95SolSi
Help with low gas mileage
i have a d16z6 i just put on an AEM ram air on and i have noticed lower gas mileage this tank im gonna end up at around 260 when i am usually at 300+. now it has been 100* plus out here in cali lately and im about to need and oil change but i was wondering if the intake could have anything to do with it?
Old 07-02-2006, 11:11 AM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: Help with low gas mileage
change your oil, re-fill, and check again. You'd be surprised how many little things go away with an oil change.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 07-02-2006, 03:23 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Originally Posted by Tyrone 95SolSi
...i just just an AEM ram air on and i have noticed lower gas mileage...
Possibly you've been driving a little bit harder since the new intake install. More power and sweet sound can be tempting for the right foot. Anyway, if the low milage still persists, try some Lucas fuel system cleaner, great stuff.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 07-02-2006, 04:46 PM
thanks im gonna try the fuel cleaner and the oil change on monday so we will see and the tanks gonna go for 275. during the next tank im getting new cap/rotor plugs and wires so it better go back up.
Old 07-02-2006, 06:25 PM
94SolGrl's Avatar
how many miles are on your motor? Might be time for a seafoam treatment. My motor looooves me since I did it
~*Emily*~
HOW TO POST PICS!
Old 07-03-2006, 04:04 PM
maddog59 maddog59 is offline
How do you use the seafoam, in the fuel or through a vacuum line? Both?
Old 07-03-2006, 04:39 PM
NA is Best!
Gas tank, crankcase, vacuum lines...your choice.
Old 07-03-2006, 04:41 PM
94SolGrl's Avatar
both... 1/3 in the gas tank, 1/3 in the oil fill cap on the valve cover, 1/3 in the brake line on the firewall. Start car, rag the HELL out of it. Rev up till you can't rev any higher, drive her hard, abuse the hell out of her. Then change spark plugs and voila. Think of it as it's like giving someone who is sick a decongestant, and abusing and ragging the car is like "coughing". I actually pulled off my catback afterwards and ran degreaser through the whole thing... black tar/carbon was all over it. Car snot, lol. Then I replaced the header (I had an aftermarket one waiting, and when I seafoamed her I used to stock header). Such an improvement. Search honda-tech for detailed instructions, and be prepared to blow spark plugs.
~*Emily*~
HOW TO POST PICS!
Old 07-04-2006, 11:34 AM
i just hit 140k and i just got my dc header in 421. so i should seafoam it then get the oil change and put the header and new plugs? fyi i got 291 on the tank and fill it with 11.236 gal so i ran her dry to get there =) should i seafoam at like half a tank?
Old 07-04-2006, 11:56 AM
94SolGrl's Avatar
seafoam at a full tank. seafoam with the stock header on, because it will get nasty. You need to have spark plugs like on standby.. as I said.. you WILL blow your plugs, which means you won't be able to go anywhere. oil change afterwards probably wouldn't hurt either
~*Emily*~
HOW TO POST PICS!
Old 07-04-2006, 12:20 PM
blow my plugs? so ill drive it till it shuts off then change the plugs? how long will that take? ill check the web page got a link -edit- honda tech
Old 07-04-2006, 06:37 PM
94SolGrl's Avatar
mine never actually shut down... you rev and drive until the smoke stops. When the smoke stopped mine was running on 3 cylinders. Changed the plugs, started her up, life has been beautiful since. VTEC hits a lot harder now... The B18c1 is a work of honda art, I swear... IAB's open at 3800 and push you back in the seat a bit, then at 5700 VTEC hits, and from there to 9000 it's a cargasm... (Yes, I have an ECU chip, and yes, I have the engine work to support it)
~*Emily*~
HOW TO POST PICS!
Old 07-04-2006, 06:42 PM
NA is Best!
Sign me up for the cargasm!
Old 07-04-2006, 11:26 PM
94SolGrl's Avatar
lol well step one is to swap in a B18c1. Step two is to build it. Step 3 is to boost it. Step 4 is to change your shorts.
~*Emily*~
HOW TO POST PICS!
Old 07-05-2006, 02:54 AM
<~~~~not wearing shorts =). thanks i will get the foam done quick question which plug wires should i get? i want blue but not sure what size where to get how much to spend thanks.
