2 & 3 Bolt Starter Motor
1992 CV LX. I need to replace my starter and the guy at the parts depot asked if I needed a 2 or 3 bolt, how can I tell without having the starter removed?? If mine is a 2 bolt can I replace with a 3 bolt?...3 with a 2?? Does it matter?
Re: 2 & 3 Bolt Starter Motor
When was the car built, check the driver's door sticker?
![]() His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels. ![]() Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps. |
The 2 and 3 bolt are not interchangable. The mounting holes are different and a different size mounting base.
Being way2old is why I need help from younger minds The sooner you fall behind the more time you'll have to catch up. ![]() HEY Y'ALL--READ THIS Here are some of our old vehicles for sale.
The motor does not matter. The starter attaches to your transmission.
BMFer1
Thanks |
MFD date, year and month.
Two bolt then.
Three bolt starters came with the May '92 and older units, and the AODE trans. You have an AOD trans, and two bolt starter (if the numbers are correct). |
Great, thanks very much!
