Old 08-07-2002, 02:06 AM
BullShifter's Avatar
Exclamation Sway bars
Front wheel drive car will benefit more from a rear sway bar than the front. So if you buy only 1 get the rear first if you want the handling.
Old 08-07-2002, 08:45 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Well if the car was set up from the factory with lots of understeer then yes that can be good advice.
If however the car is setup with a much more neutral attitude in corners, like say my car, then you could be screwed, and actualy end up with a worse handling car.
Old 08-07-2002, 11:07 AM
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
but, being a 4th gen honda civic board and we all (most of us anyway) have a 4th gen civic...
Didn't honda setup our cars for gross understeer? If so, a sway bar in the rear would be the way to go. Might also try a rear lower tie bar. You can also benefit from upper front and rear tie bars. I would do one at a time though and find out what best suits your driving style and skill. Good luck and I would like to hear results.
Old 08-07-2002, 12:27 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
I have an ST Rear Anti-Sway Bar which I will be putting on very soon. The mounts should be attached today so the rest will be a breeze.
All the Auto-Xers at Honda-Tech told me the best set up is a 22mm rear bar and stock DX/Si 18mm Front or even no front at all.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Stillen Front Strut Bar and Rear Sway Bar For Sale! redhurley Classifieds 1 02-27-2006 11:56 PM
Sway Bar or Sway Bars?? KSU03Eclipse Eclipse 2000+ 16 07-24-2005 04:02 PM
installing Sway Bars/Anti-Roll Bars and Lower Strut Bars..? tsunamiHB Tires and Wheels 5 06-08-2002 05:38 PM
sway bars? strut bars? what are these and what do they do? AznDragon Tires and Wheels 2 01-15-2002 11:52 AM
