Old 08-19-2001, 09:25 PM
Twist's Avatar
Twist Twist is offline
Gear Ratios
how do you change these in real life? Similiarly, I've heard reports of people changing their redline... How do you do this? Thanks for any help...
Initialize your Dreams!
Master of the invisble post...
Old 08-20-2001, 04:13 PM
texan's Avatar
texan texan is offline
Writer Mod
If you want to change transmission gear ratios, you must open up the tranny and start replacing gears. Depending upon the car in question, this can range from not too expensive to impossible. If you are looking to change the final drive ratio, you need to pull the differential and replace the ring and pinion gears. Again, depending upon the car in question, this can range from not too expensive to impossible.
The third accepted, but very limited possibility is to change overall tire diameter, which has the same overall effect on all gear ratios that changing the differential will. This is one of the cheapest methods to changing overall ratios, but is limited to small changes in most cases (using a much shorter tire than stock will throw off all sorts of things, suspension geometry just to name one).
Increasing engine redline is either a matter of reprogramming an ECU or changing the rev limiter, depending upon vehicle. Vintage cars don't have an ECU and thus only have a real redline if they wetre equipped with rev limiters at some point (usually these are ignition based).
The real question is why you would want to increase redline. All other things being optimized, and engine which can make the same amount of torque at a higher RPM than another will be faster overall (assuming you rev it), but "all other things" is a HUGE discussion. So before I go any further, could you explain what about increasing redline you want to know? To quickly clarify, increasing redline only on any motor will not increase accelerative ability, it will just quickly break the motor. There are many parts in an engine which must be modified or changed in order to take advantage of increased RPM potential.
'03 Corvette Z06
'99 Prelude SH
Old 08-20-2001, 04:29 PM
Twist's Avatar
thanks that was very imformative... you are truly deserving of your title "resident tech guru." Well my friend told me about a guy who had been messing with his ECU to increase redline because he had been adding a lot of mods... I didn't know how this was possible or why you'd do this, but you explained it very well... thanks again...
Old 08-20-2001, 06:39 PM
hermunn123's Avatar
hermunn123 hermunn123 is offline
Send a message via AIM to hermunn123
hey Twist, how did you get your title: Phyiscs God???
Please impede from anathematizing me just because I elocute loquacious locutions more Brobdingnaging than one could elucidate with a perspicacity as Lilliputian as your own.
Old 08-21-2001, 01:28 AM
TheMan5952 TheMan5952 is offline
Volvo Guy
Send a message via AIM to TheMan5952
if your raise it in the ECM too much with up grading the valve train you will over rev the engine, it needs to have stiffer valve springs or else you will get valve float.
-Joe- '02 Volvo S60 T5
Sold!1993 volvo 850
Intake, Exhaust, Springs, Shock, I.C.E.
Old 08-21-2001, 02:13 AM
Jay! Jay! is offline
Horizontally Opposed
At the moment it says "Dread Pirate."
Hierarchy of Subaru:
(Click to see mine!)
Compression Ratio = Gear Ratio?? The LH Engineering/ Technical 8 04-23-2006 10:10 AM
Counting Gears?/ How to find gear ratio? Link85x Camaro Discussions 8 07-08-2005 06:22 PM
Honda D and B Series Transmission Gear Ratios JD@af General Discussion 0 06-02-2001 09:22 AM
Gear-Ratio SolReaver Engineering/ Technical 19 05-07-2001 03:20 AM
Gear Ratios carmaster Need for Speed Series 0 03-13-2001 02:22 PM
