Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 06-26-2006, 11:59 PM
98CivicDXMT21 98CivicDXMT21 is offline
Exclamation INTAKE HELP! Please asap
I recently bought a cai for my 98 civic off ebay for $35, "brand name" dr.speedy-it locates the filter under the car but after reading many comments on this site i see that it can only cause problems with water, dirt, etc., and that rai is the way to go. i dont really wanna buy a whole new rai and not use the cai, could i just saw off the pipe and have a makeshift rai? good idea or bad idea?
Old 06-29-2006, 02:55 PM
mfmark5007 mfmark5007 is offline
Re: INTAKE HELP! Please asap
CAI's, although more exposed to the elements of nature, can only do your car great harm if it is pretty much submerged in water. Regular rain won't do much. As far as dirt, those filters are usually reusable/washable.
WTF
Old 06-29-2006, 03:19 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
I vote to saw the end off. I like the piece of mind knowing that I can drive through a puddle at more than 5 mph and not worry about hydrolocking.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 06-29-2006, 04:07 PM
Alex37211 Alex37211 is offline
I had a VTEC del Sol with a CAI and one day durring a heavy downpour, I had to pull off to the side of the interstate while it was practically flooding and I got water in my engine. It ended up throwing a rod and I had to replace the engine. I kept the same intake but sawed it off like you're talking about doing. It worked out fine after that. Try to get the end of the filter as far to the front passenger-side corner as you can since this is the coolest part of the engine compartment. Good luck.
Old 06-30-2006, 01:10 AM
Exclamation Re: INTAKE HELP! Please asap
Here's a picture of the intake...
If i wanted to saw it off and make a short ram one instead, where would i saw it off? also this didnt come with directions for installation, just the parts. if anyone could write up some simple directions and post them thatd be awesome.
http://cgi.ebay.com/ebaymotors/96-00...spagenameZWDVW
Old 06-30-2006, 10:59 AM
big tex84's Avatar
big tex84 big tex84 is offline
they make a bypass for the cai's that if get submeged it bypasses and doesn't suck up the water into the engine
Finally getting my swap done, Thought I would be relieved and satisfied, now I just wanna spend money on other car parts, WHERE DOES THE MADNESS END!!!!
Old 06-30-2006, 05:17 PM
TurboLaxx's Avatar
TurboLaxx TurboLaxx is offline
Why is there an exclamation point, capitol letters, and the phase "asap" in this topic title. This isnt an urgent thread. This is a normal thread with a common question. Please dont do this in the future unless you're late for work or something that's time sensitive. Crap like this makes me not want to help you....like crying wolf.
Old 07-01-2006, 04:41 PM
00accord44's Avatar
00accord44 00accord44 is offline
High on Potenuse
Send a message via AIM to 00accord44 Send a message via MSN to 00accord44 Send a message via Yahoo to 00accord44
I don't know if I'd reccomend the bypass valve for the intake. I've heard more than one person report that the bypass valve itself was sucked into their manifold. The bypass is just a rubber retainer with some foam around it but apparently the foam separates itself from the retainer when put to the test.
I have a bypass valve but didn't install it after I heard the negative reports. As far as sucking water in through the cai, when its raining heavily just drive slower (which you should be doing anyway) and avoid the puddles. At least the really deep ones. That and stay in the left lane when possible since most roads are banked.
ECNATSISER AL AVIV
Old 07-02-2006, 04:15 PM
NA is Best!
Like it was stated earlier, the by-pass valves give a false sense of security becuase they only work when the filter is sumerged. The intake in that picture is not for a civic. When you get the one for your car, put it on and look at some pictures of other civics with ram air intakes and make your cut where ever looks close.
